Last edit by: IB Advertising
Browse all: Toyota 4Runner 4WD - Four Wheel Drive Guides
- Toyota 4Runner 1996-2002: How to Replace Driveshaft
Super article with modifications, Review and How-to
DIsconnecting Rav4 driveshaft?
I don't know for sure, but it shouldn't be too bad. Disconnect it at the rear axle and not at the XF case. You can then get some heavy straps and strap it up to hold it out of the way and let the rear diff turn freely. If you disconnect it at the XF case, then the axle will still spin and will eat through the strap and fall - bad. Or you can completely remove it if you want to be EXTRA safe.
I know that the RAV 4 has a similiar AWD system as my All-Trac. Mine has a switch located on the back (firewall) side of the transmission. It can either go in AWD, FWD or all in N. Of course they only recommend the FWD or N for towing only.
Call the dealership and see if they have anything like that on the RAV.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
kawazx636
10-06-2021 03:03 PM
2002, 4runner, 4x4, 89, 96, disconnect, disconnecting, drive, driveline, driveshaft, rav, rav4, shaft, strap, toyota
