difference between gen 1 Taco and T100 front rotors
I'm looking to upgrade my T100's brakes all around, and I'd really like to get some higher-end DBA rotors for my truck, but they only manufacture for the Gen 1 Taco. I was wondering if anyone knew what the differences were between the two or whether rotors were interchangeable between the two.
Any input is greatly appreciated!
If you look at a DBA catalog, there are rotor dimensions A, B, C, D, & E. If you have those dimensions, then you can compare with the DBA rotors for other Toyota Trucks and SUVs.
If you decide to take measurements, that would also be a great time to check the bolt position & spacing of your calipers to see if the Tundra brake upgrade suits your T100.
HTH
HTH
