DID you Know...oil Cooler
Old 07-16-2008, 07:20 AM
hross14's Avatar
Did you know that we have an oil cooler on the 5vz-fE? I am getting a motor rebuilt and when i took it out (motor) there was this cannister like thing on the side of the block with water hoses. figured it was there for whatever reason.
Then, i was looking at the engine componest section of a FSM and it called it an oil cooler. I suppose water runs through there much like an auto tranny set up.
Old 07-16-2008, 07:26 AM
Team420's Avatar
I think all of our motors have them...I know my 3vze has one.
Old 07-16-2008, 08:34 AM
TexanTaco's Avatar
That's cool, literally.
Old 07-16-2008, 11:22 AM
SpeedBro's Avatar
tacoma and 4 runner with 5vz had all oil cooler, but some V6 tundra didn't
why I don't know
Boris
Old 07-16-2008, 11:28 AM
TexanTaco's Avatar
^ But that's a different V6 in the Tundra right? It probably didn't need one.
Old 07-16-2008, 12:29 PM
hross14's Avatar
It just suprised me to know we need an oil cooler and that is how they went about it. never wudathunkit
Old 07-16-2008, 12:31 PM
hross14's Avatar
i am actually thinking i might take it off and just add a remote oil filter with an inline cooler? Because getting to the filter with a full skid is not fun--face it changing the oil even with a regular skid isnt that fun...
Old 07-16-2008, 12:40 PM
SpeedBro's Avatar
00-04 V6 tundra had the same 5vz
05+ V6 turndra had the 1GR
Boris
Old 07-17-2008, 10:32 AM
98runner210's Avatar
+1 Every damn time I drop the filter into the skid and spend 5+ minutes trying to find the exact spot where I can fish it out. Then have to make sure and throughly clean out and oil with brake cleaner. I was thinking of a remote oil filter kit but that just seems like so many more opportunities for a leak.
Old 07-17-2008, 11:09 AM
TexanTaco's Avatar
Boris
I didn't know that, very cool. Most 00-04 Tundra's I see have the i-Force V8.
Old 07-17-2008, 12:28 PM
hross14's Avatar
I have tried to do the oil filter relocation things before with a kit i thought would work----never again--just when i got home the hose blew off and almost ate the motor.
Now if there was a really good one with AN fittings and "last for ever bad arse hose" then I would get it and install it while my motor is being built.
Old 07-17-2008, 12:56 PM
BigBallsMcFalls's Avatar
ur doing it wrong.
the first step is remove skidplates.
air gun+socket=both plates dropped in 56 seconds
Old 07-17-2008, 01:35 PM
TexanTaco's Avatar
Originally Posted by BigBallsMcFalls
ur doing it wrong.
I haven't removed the skids to change the oil, and it's a pain because oil drips down in 15 different locations after you're done! Next time I will remove the skid plates. I really wish the oil filter was in a easier location also. I wonder if Toyota techs remove the skid plates? (considering how fast they try to get stuff done)
Old 07-17-2008, 02:52 PM
I used to always remove the skids but if I can catch the filter I don't have to remove the skid.
Old 07-18-2008, 11:24 PM
Yota Runner's Avatar
Another thing to keep in mind if you change your own oil...It's not a bad idea to pull the skid anyway, even if its a pain because it gives you a better look at whats going on with you engine... check for leaks and whatnot My .02
Old 07-19-2008, 03:06 AM
ARB1977's Avatar
5 bolts, 3 in the front and 2 in the rear...she comes down in one piece. It takes 20 mins if that to change oil, filter and reinstall skid.
Old 07-19-2008, 04:26 AM
pkt1213's Avatar
I just turn the front wheels to the left and then you can unsnap the wheel well liner and push it aside. It makes it a lot easier to get up to the filter than trying to snake your arm up around .
Old 07-22-2008, 06:23 AM
hross14's Avatar
You know i have been told that and i guess i just get used to doing something one way. Maybe i will give that a try next time and SANs the relocation effort
Old 07-22-2008, 06:40 AM
TexanTaco's Avatar
I'm definitely gonna remove it next time.
Edit: AND I will start using Wix oil filters, or buy a couple Toyota ones.
Old 07-31-2008, 06:42 PM
Swede's Avatar
I've had my remote filter set-up for over 4 years now and no problems whatsoever. It sure works great for oil changes but in the back of my mind, I have never felt completely comfortable with it knowing a hose can go at any time. I'm seriously considering going back to the OEM set-up, and now that I've installed a body lift since then, getting at the filter from the wheel well instead of underneath. There is a lot to be said about "peace of mind".
Quick Reply: DID you Know...oil Cooler
