Cleaning a spray gun after use of bedliner
hey guys hopefully this weekend ill bedline my bumpers. but i was wondering how i/if i can clean the spray gun after the use of the bed liner?
Lacquer thinner and some thin pieces of wire to gouge down into it. I had to take my gun apart at least 5 times to clean it during the course of sparying a bumper using Duplicolor bedliner.
Good luck.
thanks never thought of that... the duplicolor stuff is what im going to be using also. can i just put the thinner in the gun and spray it out to clean the nozzle
what kinda gun did u use? did u just buy the cheap one from walmart?
I used the Duplicolor one and tried a Harbor Freight one, both clogged up after a while so paint as much as possible before you stop even for a minute cause once you stop, it clogs...
Lacquer thinner...
i dont know if its the same for the duplicolor but the herculiner can be thinned with xylol alcohol b/c that is what the base of it is. as far as cleaning it, acetone works pretty good as long as it hasnt hardened.
Jcrawl94
10
10-24-2015 04:34 PM
