body lift and auto tranny shifter
Senior Member
After I did my 2" BL, I noticed that the little red line next to my auto tranny shifter didn't line up with the gear I was in. Anyone else notice this? Is there a fix? My wife is really nervous driving it this way.
Dunno
Mine did that crap all the time, just watch what it says on the dash and you'll be fine. Now that the body lift is off, it is gone. I'm sure the body lift messes up the angle/linkage and throws the little orange indicator off a tad.
Mine did this as well. I fixed it by loosening the bolt on the shift linkage, allowing for further adjustment, then I tightened it up when it was right. Maybe it will help to put the transmission in Neutral (engine off of course & parking-brake on) and climb under, make the adjustment, and peek up at the indicator to see if it is lined up.
i'm 1.5" body lifted and mine is good. i have noticed it be off a couple times, but then it somehow got back to normal. good to know i can fix it if needed.
Senior Member
96s don't have the display on the dash. *sheesh*
Senior Member
Which nut are you talking about... under the center console, or down by the tranny?
Look at RB's install instructions
I just losened the trans shifter linkage when I put on the lift and then tightened it up after I put on the lift. I figured if it was loose it would adjust its self. It didnt end up moving but just a little bit. My shifter has never had any problems with the red line.
Senior Member
Originally Posted by Mossback74
Senior Member
I finally got around to adjusting the linkage - worked great. A little PB Blaster and the nut loosened right up. I tried a few different positions until I found one that worked. For me, I had to slide the botl all the way forward in the linkage.
Thanks guys.
Thanks guys.
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
09-04-2015 09:27 AM
Iceman4193
07-15-2015 04:48 PM
