Best way to clean & oil Trueflow air filter
Mine needs to be cleaned, i lost the box and the link on their website doesn't work properly, so if anyone could let me know the best way to clean it, thanks.
Run lukewarm water through it from inside breathing surface to outside
let dry a long time-shake it once in a while to knock off the droplets
avoid temptation to use hair dryer or microwave to dry it out
Re-oil and let sit again. do not over oil. Shake and make sure no loose oil shakes off.
Did you buy the True Flow cleaning kit and just need to know how to apply it? If not, you need to buy the kit.
EDIT: Here's a link to buy their cleaning kit and instructions on how to:
http://www.hyperformanceauto.com/sto...5891C4658.aspx
Here's another one: http://www.autoanything.com/air-filt...A1964A0A0.aspx
Do it right and buy the kit!
I have a dumb question, more of a clarification question. When I spray the oil back on, am I spraying the back side too? The side with the metal mesh? I know with K&N you only sprayed one side... but the instructions say to spray "inside and out" for true flow.
trust the moderator
yes Rocket has it exactly right-do not overspray to the point of saturation-and let it sit for quite some time then check for drips so you can see if you did overspray it.
different filter media
Why not just trade your old respray kit with someone with a K & N or swap for some other part with them?
between this forum and T4R.org you should be able to find someone willing to trade/buy/donate.
I read somewhere that "normal" air filter oils aren't to be used on the trueflow filters. I wish I could remeber where... lol
1 Post
I have a K&N. I used the suff that they sell and it works OK. I now use warm to hot water and some dish soap. Works great!
Yes, oil LIGHTLY! Too much oil and you gill gum up everything past the filter.
Hey just incase anyone is looking http://www.xtremediesel.com/index.as...OD&ProdID=1093 has the kit for $11.95 + $7.47 shipping (deppending on where you are). It's a little cheaper then going w/ autoanything.com
09-04-2015 09:27 AM
88runnergomas
07-09-2015 01:12 PM
