Best three gauges for my money pit?
I know that I want to add some gauges and I'm tying to prioritize. These will most certainly all be Autometer Z series gauges as I'm strongly cosmetically oriented. There are five that I would like but am pretty much unwilling to get more than three as that will look the best for my plans. They are:
1) boost/vac- just for looks
2) AFR- certainly functional and I believe this one is necc. However this model doesn't provide the actual ratio only an LED bar graph. I'm pretty sure I can come up with the translation.
3) EGT- I think I want this as it also seems to be one of the more important diagnostic tools.
4) Trans. temp- I'm not sure how important this really is as I will rarely be towing and am putting in the Hayden 678. Anybody have experience with both a tranny cooler and a gauge?
5)Fuel pressure- The priciest of all the gauges and I don't know if it is necc. as I am putting in the Walbro 190. Anybody have experience with both the Walbro and a fuel pressure gauge. And if the pressure is too low nothing can be done on the fly. I assume I would just know that something isn't working as it should?
I have listed these in what I believe is the best priority for me but welcome experienced feedback.
most definetly in order of importance:
1) boost
2) Oil temp
3) EGT
4) Fuel Pressure
5) Water temp
and most importantly, a WIDEBAND gauge. A/F gauges are useless because they take the signal off the stock o2 sensor and it is pretty much just a light show. Remember that you can't use your EGT gauge as a tuning tool. It can be used as a rough tuning measurement, but by the time your EGTs hit too hot the damage is already done.
1) boost
2) Oil temp
3) EGT
4) Fuel Pressure
5) Water temp
I'm assuming you're boosted I would say EGT, A/F ratio and trans temp gauges are the most important. Followed by intake temp, fuel pressure, oil pressure, water temp, and boost gauge.
