Before and after....sort of
Playing around in photoshop
Before:
After: (The rack is my own design, I've got a friend who is a good welder and we're working on that right now. Also working on the rock guards on the bottom. I'm trying for a 4" lift with 32x11.5x15 m/ts, also removed decals, dent in the rear and flaps)
shop:
Before:
shop:
It always starts with a dream. Btw, I have removed that exact stripe. PITA. Took like 10 hours work all said and done but worth it. Just a hair dryer and some goof off .... and a lot of hard work.
Just a note on the stripe removal, or any graphics, adhesive, etc. There is a tool that professional body shop guys use to remove such things. It's basically a giant eraser on a wheel. It would take the stripe right off, like within 1 hour rather than 10.
-Wrench
here is something to think about, those slider supports angle a lot, and would probably not support properly with a direct rock slide to them, might bend in...
also if you plan on making hte rack that big.. watch out, as the shells roof is probably fiberglass and may not be able to support that, and the roof of the truck wasnt setup with rails on it, so you would have to figure out someway to mount it, maybe a front like channel clip on lightbar and in hte rear maybe an exterior rack to come up on the sides or something where no direct stress is placed on the fiberglass....
I used one of thoes erasor wheels also and it was still slow going. I alternated between berthe two methods. They both take a long time.
personally i wouldnt screw with the shell, it just wasnt designed to support weight like that.... however, your ide4a about the rack seems to be ok... like a ladder rack basically with a basket on it... the overhead part of our worktruck ladderrack that stems off the flatbed on a fullsize chevy is plenty strong and not connected to the cab at all.....
Originally Posted by viperdan
anyone know what the max weight limit of a fiberglass leer shell is?
With wide enough "feet", I doubt you'd break through.
Thanks for the advice. I can't wait to finish the rack. Theres alway more to do though... 4.88 gearing, Ox locker, winch, the list goes on and credit card company get happier.
Ah yea, definately good advice, I payed for the truck in cash and only now have I been using my CC. I've actually got a seperate savings account for my truck.
Debt scares the hell out of me.
Debt sucks. Took me about 7 years to pay off my credit cards from my younger years. Never again.
Just another tip for anyone using the eraser to remove graphics.... the trick is to keep the rpms down on the tool. If you rev up your grinder, drill, whatever, you'll only end up heating the adhesive and making it more difficult to remove. Keep the rpms down, don't concentrate on one spot too long if the adhesive starts to get hot. Works great with a little practice.
-Wrench
-Wrench
-Wrench
-Wrench
