Anyone work at a dealership who can look this up?
So, I need to replace this A/C line. I cannot find it anywhere online.
2004 Tacoma double cab. 3.4L 4x4 TRD.
This line runs all the way from the condenser to inside the A/C core inside the cab. Its basically once piece, but mine was hammered in the accident. I cannot find this in any exploded diagrams or anything. All of the the ones online are two different lines. This one isn't. Its bolted to the expansion valve inside the box. The smaller line runs through the firewall and all the way to the condenser. The larger line runs through the firewall and has a large fitting to connect the discharge line.
Why on earth Toyota didn't put a fitting on this at the firewall is beyond me.
I talked to my friend at toyota and he explained to me that there is a clamp on that line right after it exits from evap box. He said it can easily be missed because it takes a special tool to remove or it will break. So it is a separate line and available and clamp also if it's broken. Hope this is helpful. If you need any further info PM me and we can connect by land line.
ashersullivan88yota
01-18-2022 05:37 PM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
madxman21
07-09-2015 10:26 AM
