Another rear window question...
Old 05-31-2006, 06:03 PM
ebelen1's Avatar
Since it's been getting pretty hot where I'm at and I park the truck outside, I've been cracking the windows, including the rear window. What I noticed today is that the rear window when cracked, is pretty loose.
I have no issues w/ it going up and down but is this normal? I was thinking that it should stay pretty firm as the regular windows do when they're down a bit.
Old 05-31-2006, 06:14 PM
neliconcept's Avatar
mine can be moved around quite a bit when its cracked or half way down.
i use mine quite a bit
Old 05-31-2006, 06:47 PM
snap-on's Avatar
loose, like in and out of the track or tilting side to side?
i use mine daily almost havent noticed any looseness to it persay...
Old 05-31-2006, 06:58 PM
d0ubledown's Avatar
mines a bit loose too when part way down..no problems with it either so far. it bangs around abit when i close the rear hatch with the window cracked.
im guessing this is normal since it probably needs a bit of play since it goes up at a bit of an angle...
Old 05-31-2006, 07:18 PM
Jimmeh's Avatar
It is normal. Our old 1990 4Runner was exactly the same way, and when my 4Runners window was working and down about maybe 3 to 6 inches, it would shake and rattle quite a bit. You shouldn't worry too much about it until it is banging around so hard that it is on the verge of cracking/breaking.
Old 06-01-2006, 06:53 AM
gpcollen1's Avatar
Normal....
Old 06-01-2006, 07:24 AM
ebelen1's Avatar
Thanks guys, this is definitely what I'm experiencing. No biggie just wondering.
06-01-2021 01:51 PM
RustBucket
07-24-2015 04:46 AM
sabine
07-18-2015 03:59 PM
icentropy
07-14-2015 10:23 AM
coryc85
07-06-2015 04:07 AM
Quick Reply: Another rear window question...
