AS air suction valve
Old 07-24-2003, 03:57 PM
muddyboots's Avatar
Post AS air suction valve
93 4RUNNER V6 DOES ANY ONE KNOW IF THE AS EMISSION VALVE SHOULD BE SUCKING IN AIR ALL THE TIME ?
Old 07-24-2003, 07:52 PM
mtnfreak's Avatar
Here's what the '89 FSM says, probably the same for you (I'd attach it if I had a scanner) - during 'normal' driving, with the coolant temp below 35degC/95degF, the VSV (vacuum switching valve - the one hooked to the little black & orange check valve) should be on, as well as the AS Reed Valve. During deceleration with the throttle at idle and the coolant temp above 35degC/95degF, both should be off if the engine RPM is below 1000. Between 1200rpm and 3200rpm both should be on. Sorry, but I can't explain more without the pictures in the manual.
Old 07-25-2003, 09:04 AM
muddyboots's Avatar
yeh thanks its just that on idle the 'AS' VALVE with the electrical terminal is sucking air in big time and i have just failed aircare due to the NOX being 1.7 but no trouble codes and no problems that i know of . EGR valve works so who knows may have to spend money to find problem
calderp
Engine Swaps
08-16-2016 05:15 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
calderp
07-27-2015 09:58 AM
gmonnie123
07-26-2015 02:44 PM
sojourner567
07-16-2015 08:52 PM
Quick Reply: AS air suction valve
