Added 1/2" more of Diff Drop...CVs WORSE?
Old 09-08-2004, 07:37 PM
BajaRunner's Avatar
Yeah, so I got some 2" washers today, 1/2x9" bolts and added approx. 1/2" more of a diff drop to my current 1" RB drop.
For some reason the outer CV boots look the same, maybe worse. The inner ones look worse for sure.
I think by dropping it down further, it pushed the diff forward, and now looks weird.
Is this a known problem with adding more diff. drop or what?
I'll have pictures up soon.
Old 09-08-2004, 08:35 PM
BajaRunner's Avatar
Here are the pictures.
Outer CV:
Inner CV:
Old 09-08-2004, 08:39 PM
keisur's Avatar
also the cv's will come closer to the lower arm when flexing and the front driveshaft is at a greater angle at the companion flange on the front diff. It's actually not good to lower the diff unless you can lower it evenly. basically what you're doing is only lowering the front of it.
Just get a manual hub kit from ORS and you won't have to drop it any.
Old 09-08-2004, 08:46 PM
Guest
fourunnabilly's Avatar
Billy say, screw the diff drop. I understand where you are coming from, but the results rendered from it are not worth the time or effort with just 3" of lift. I am at over 4" on my 4th gen, and though I know I am definitely pushing the limit, I could probably add another 3/4" or so and get away with it. This is all without a diff drop.
Just keep an eye on your boots, listen to your cv axles, and keep everything lubed up. You'll be fine. I just dont like the idea of sacrificing front end ground clearance, but to each his own. Good luck, dont stress over the issue.
Billy
Old 09-08-2004, 08:49 PM
keisur's Avatar
my thoughts as well.
BajaRunner's Avatar
Thanks guys... You make me feel a little better
Keisur, what is ORS? I am interested in a manual hub kit. Do I have to have one made for the 3rd gen or can I use earlier models?
Old 09-08-2004, 08:56 PM
Guest
I would assume he is speaking of "off road solutions"
Billy
Old 09-09-2004, 04:53 AM
keisur's Avatar
oops, sorry, I meant to post a link - I haven't done it yet, but mainly cause it's about 1200 bucks.
http://www.offroadsolutions.com/tech...conversion.htm
and a pic:
Old 09-09-2004, 07:07 AM
BajaRunner's Avatar
Oh man...
Yeah, thats nice and all, just kinda expensive. Maybe when I start working again I can afford that.
Old 09-09-2004, 07:58 AM
keisur's Avatar
Oh man...
my thoughts exactly. after enough cv boot replacements I suppose I'll break down and get it.
justdifferentials
14
06-11-2017 08:36 PM
pickle6415
10-19-2015 08:08 AM
skouba
09-14-2015 06:58 AM
Boomer8404
09-10-2015 09:01 AM
zz_denis
09-06-2015 03:43 PM
Quick Reply: Added 1/2" more of Diff Drop...CVs WORSE?
