AC Recharge on a 96
AC Recharge on a 96
Hi,
I have a 96 runner and lately I have noticed that the AC is not getting that cold, especially in very warm weather 90+. Anyway its all original and running 134a.
My question is I am looking at buying the recharge and doing it myself. Should I buy just the can with 134a. Do I need to buy the oil charger, do I need the gauge. Or should I just buy the can that has the 134a, oil and gauge and be done with it? The one with all 3 is 25 bucks from Kragen.
Also do I need to evacuate the whole system before I recharge? Anything else I should take into consideration before I do this?
Thanks for your help.
Just take it to a LICENSED MVAC technician. They have the proper legal equipments to recover, vacuum, and recharge it.
Edit: Just to answer your question. Yes you do need to evacuate it, but how are you going to do it with out a machine? It's illegal to vent it into the atmosphere. Also you have to pull a vacuum to determine if there are any leaks in the system. If no leaks are found after the vacuum you have to add whatever amount of oil you've recovered and then recharge according to manufacturer's specification.
Thanks for your reply.
I assume there are no leaks, just due for a recharge. Why is evacuating the system necessary?
Obviously I am trying to avoid a large bill if I can do it myself. Also I would never evacuate myself.
Technically you are not supposed to "top off" refrigerant. Ideally the refridgerant is supposed to be permenant as long as there are no leaks or system failures. Evacuation is necessary to pull out the existing refrigerants and oil in the system, but a vacuum is necessary to pull any other contaminants and to check for leaks.
Mark, just buy a 12oz can of 134A and add it to your system. 12 ounces should not be too much to over charge your system. If after adding the freon and it's still not cooling enough be careful when adding a second can as it could overcharge. Check your suction line (the larger line)for coolness and condensation. The discharge line will be hot so be careful. When adding freon you must use the suction line with your A/C running. If your lucky you should be good to go for several more years depending on how bad the leak is. Most leaks are in the evaporator or condensor coil and will cost a small fortune to replace either coil.
Good Luck,
beard
Ps, 134A is ozone friendly.
Good Luck,
beard
Yes, but you can still be fined by the EPA if you knowingly recharge any A/C system and it's leaking.
gray- thank for your reply. I thought that over the years an AC system would normally discharge, so i never thouhgt I have a leak. Still not sure. the AC does get cold, just not as cold in very hot environments. Still does the trick though.
I'm not sure If I should leave it alone, or maybe stick a can in like you suggest. I definately dont want to make it worse.
Is there a write-up to add freon?
Also, make sure the engine cooling fan is working properly. To test, simply attempt to turn it after shutting the engine off (full operating temp). It should not spin by hand at that point.
I doubt this is the problem though.
Guest
Posts: n/a
Originally Posted by superjoe83
if there were no leaks then you would never have to recharge it, you have a very small leak some where, evacuating is necessary to remove moisture, air and any other contaminates, and to see if the system holds a vacuum
Originally Posted by Tomsriv
Although it isn't a bad idea to start fresh, you don't need to purge the whole system. The receiver/dryer (the round canister in front of the radiator with the sight glass) is designed to hold contaminants and moisture. Eventually it will get full of contaminants, but most last the lifetime of the vehicle. Most of the 30 year old muscle cars I worked on growing up still had the original receiver/dryer on them.
thanks for the tip
Don't just blindly dump a can into the system. Get a guage from Autozone and check the pressure first. If you overcharge, the system will have the same symptoms as undercharge and won't cool at all. Only way to get it right is with a guage.
Second the opinion that there has to be a leak somewhere if the system is undercharged.
The gauge will tell you pressure but not when the system is full. Use the sight glass on the reciever drier and charge it untill there are no bubbles.Also charge vapor on the low side (big line)Also it is normal to lose some refrigerant at the compressor seal. check the connections and lines for an oily residue that is your leak
I turned on the AC this weekend while watching the glass on the reciever drier ( the cannister looking thing by the grill). by the time I got tot he front of the truck I was still able to see bubbles. This cleared in about 10-15 seconds.
does this mean it is low?
This is not to say you can't recharge with those little kits you get, but the results are definately not guaranteed and if you didn't fix the leak, you'll need to get another kit (no way to recover the freon). When I used to work as a mechanic we had quite a few people come in after trying to fix their own systems with those kits (a few even did more damage by over-pressurizing the system too far). Even to this day that is one of the few things I bring to the shop to have done.
Once again, a gauge will not tell you if the system is full or not. R134a is measured in lbs as in weight. Not as pounds in psi. When you watch the sight glass do the bubbles stay gone after you run the system? and does the compressor clutch cycle on and off? the clutch is controlled by pressure switches (high and /or low pressure) and by a thermistor switch ,which detects the temp of the evaporator. also ckeck the heater control valve to make sure it is not allowing hot coolant through the heater core as this will raise the temp in the hvac box
nanhodges2733
05-29-2020 03:28 PM
bryan34w
12
09-30-2015 02:50 PM
