98 toyota 4runner - replace axles
Hello everyone,
I saw a 98 Toyota 4runner Limited V6 4x4 for sale now for $2,000.00, but the Axles/Drive Shafts/U-Joint are bad and some damage on the body, but the Engine and Tranny are still good. Is it a good price to buy in a condition like that for the price?
I already talked to two shops and they charge me $950.00 and $1,100.00 to fix the Axles/Drive Shaft/U-Joint. In this case, if I buy it, I plan to replace the it myself, so how hard is it to fix?
I need your opinion/advise please.
I'm sorry. I don't really know the part's name. Let's call it Drive Shaft or U-Joint. How hard is it to replace the new one?
For example, painting the Mona Lisa was easy for DaVinci, but I sure couldn't do it.
Replacing a stock Toyota u-joint is difficult even for an experienced person. I usually let a shop do that. Simply replacing a drive-shaft with the attached u-joints is pretty easy if you can find an exact replacement. You just need 2 14mm combo wrenches.
If that estimate you got is based on what you told him, I wouldn't trust it since you don't really know what exactly needs to be replace/fixed. There are 2 axle shafts, a differential (with pinion, ring gear, bearings, spiders, etc), housing, brakes.
Thank you for your advising, tantacoma. I don't have much knowledge about car. If it's hard as you said, let me think for a bit and then make a desision either buy it or ignore it. I'll be back here to let you know.
JaredL
06-16-2015 04:47 PM
