95 taco 5 speed hydraulic clutch prob
I was told the master and slave were still good as long as there was no leaks clutch is sponge and let's all way out 1 inch off floor and I bled it to day and still nothing has changed with foot on floor it will eventually let itself back out and every now and again it will just go to floor
Staff
A leak is not always a sign of a bad cylinder. Brake fluid is harsh on the rubber seals so if the fluid is leaking past the cylinder, basically the same effect that you are seeing. You using part store replacement parts? Numerous threads on them failing. Stick with Aisin replacement parts.
ripp96
07-31-2015 11:14 AM
ripp96
07-25-2015 02:32 PM
