95-3.0 Head Gasket
Old 10-16-2005, 12:27 PM
fritzy's Avatar
95-3.0 Head Gasket
Any advice on getting HG replaced under factory recall?
Old 10-16-2005, 12:32 PM
CoedNaked's Avatar
Good luck with a 95.
Generally speaking the 95's were considered one of the only years where they had the "right" head gasket. My uncle has a 95 pickup with 3.0 and he ran it to 300,000 KM's without any head gasket problems before he decided to rebuild simply because he wanted to keep the truck.
Old 10-16-2005, 12:44 PM
Paul H.'s Avatar
call Toyota up and ask.
Old 10-16-2005, 05:31 PM
gonzo's Avatar
95-3.0 Head Gasket
toyota case line is 1 800 331 4331
V06 Recall
call them and try.
my 95 4runner was done before i bought it . i checked before buying it. so they do cover at least some 95's. good luck.
Old 10-17-2005, 01:46 AM
ThomasJ's Avatar
I have a 95 and it was covered. However, I would spend the extra money and get ARP head studs and have them tourqe them to ARPs specs. And re-tourqe them after a few heat cycles. All head gaskets will have some settling during the first few complete heat cycles. This releases tension on the studs/bolts and that leads to HG failure.
Old 02-23-2006, 12:02 PM
lng24run's Avatar
I had a 95 and just called and I am not covered... bummer
Old 02-24-2006, 07:17 PM
bgibb's Avatar
I had a '95 that wasnt covered either...the early '95 model was but mine was considered a '95.5 where they "fixed" the problem...it will depend on what month your rig was actually made in '95...good luck
kgcwb44
01-29-2023 10:02 AM
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
themightykhoner
08-11-2015 07:37 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: 95-3.0 Head Gasket
