4runner's a liar
4runner's a liar
Ok well I've had my 4runner for like 2-3 months and I realized my 4x4 doesn't work at all the cables work the axle moves and the 4wd indicater lock goes on but still when I roll up on a rock nothing my back tire jus spins what is goin on? Its on an 85 runner
Originally Posted by midiwall
When I had that symptom on my truck, it turned out to be a broken CV. I never had the normal "bag of rocks" grinding... In fact, I figured out that I probably drove 500+ miles on that axle.
The way I finally figured it out was to get all 4 wheels off of the ground, then start the engine, throw it in gear and kick in 4WD. That's when I saw the right front axle spinning and the tire not moving. I'd popped the outer joint.
Thanx for the replys I hope I didn't break a boot cuz I must have bout it like that
4 wheel drive is not truly 4 wheel drive. It's the right rear wheel and the left front wheel that are truly engaged. If someone put lockers in the truck then it would really be 4 wheel drive. Which wheel is spinning when you pull up to a rock? You need to give up more details.
Originally Posted by calg3
Mark, that is good information for us 3rd Gen guys but in his post he says he has an '85. I am not sure this guy knows anything based on his comments, so if he does have an '85 he probably does not know he needs to lock the hubs to have 4WD. Just a guess...
Carry on!
Never seen any cables on my '85 nor any boots on the axle. 4WD light is turned on by a switch in the transfer case. So with 4WD light on, does the front driveshaft turn? If so, shift into 2H and then lock the front hubs (turn the dial pointer from Free to Lock) and see if the front driveshaft turns when you move the truck or if stopped that you can't turn the front shaft by hand. If both the above two tests are positive, then you likely do have functional 4WD.
If you have auto hubs instead of manual hubs, then they may not be working properly:
http://www.off-road.com/toyota/tech/aisin/index.htm
Flying91
45
04-11-2024 04:39 PM
BeMiceElf
10-10-2015 09:40 PM
