3"Bod lifts with auto trans?
I recently had some buddies assist me in installing my 4Crawler 3" body lift. The only issue I have been thinking about fixing was my shifter linkage. I had to buy the extension that drops the Tcase down 3 inches but that did not allow my linkage for my 4WD to reach the arm on the Tcase. It was still an inch shy. I tried messing with it but nothing worked. I ended up cutting a piece to backyard it together until I can do a perminent fix. It works but is tight. Has anyone done a 3" body lift on a 2nd gen that has the auto? If so what did you do in this area? I guess from the sounds of it my 4Runner was one of the few 2nd gens with an auto that 4Crawler did the 3" BL.
Blue
Blue
The transmission spacer they sell for $45 is supposed to correct this problem but I dont see how the linkage is to reach. My idea is to weld a 1-1.5 inch piece in the middle of the linkage to correct this issue. I know it will work but its the taking it out and locating someone with a welder that is another problem. My temp fix is working out ok for now.
06-01-2021 01:51 PM
D.B.T. 87 4x4
07-20-2015 04:51 PM
