3.4 Rev Limit?
Old 05-11-2007, 10:28 AM
mikes984x4's Avatar
Question 3.4 Rev Limit?
I'm new to this forum thing, but I'm glad to say I'm finally a Yotatech member. Anyway, I'm wanting to know what the rev limit is supposed to be on the 3.4L. I'm asking because after a recent trip to the shop to get work done due to a timing issue, my rig will only hit 4,000 rpm before it cuts out. If I remember correctly, before the shop trip it would rev more than that. Any help will be appreciated. Thanks!
Old 05-11-2007, 10:47 AM
Tron's Avatar
I have had mine up in the 5k range. You should be able to get above 4k.
Old 05-11-2007, 11:00 AM
mikes984x4's Avatar
Believe me, I've tried to get that sucker above 4,000, but once it hits that rpm, it's like the fuel is being cut to the motor. I know it sounds wierd, but it just won't go above 4 grand! So, does anyone know how I might be able to fix this, with or without taking it to the shop?
Old 05-11-2007, 11:04 AM
DirtyDeeds/DirtCheap's Avatar
I've been up in the 5k range also.
Old 05-11-2007, 11:07 AM
mikes984x4's Avatar
See, that's what everyone keeps telling me, even my cousin who has the same rig as me. But it just simply cuts out at 4000 rpm. So what could be a possible fix?
Old 05-11-2007, 11:11 AM
hross14's Avatar
timing belt out of whack?
Old 05-11-2007, 11:13 AM
Do you have an intake and(or) exhaust mod?My rev limit was about the same as yours until I changed the intake and exhaust.
Old 05-11-2007, 11:16 AM
mikes984x4's Avatar
No, the timing belt is brand new, only about 4,000 miles on the truck since the trip to the shop. The only mod I've done to the motor is the ISR mod with a drop in K&N filter, but I had already done that before the shop trip, and it would rev above 4000 then.
Old 05-11-2007, 12:06 PM
mikes984x4's Avatar
3.4 Rev Limit?
O.K. I just went to town to get gas for my truck and on the way back decided to let her rip to see if I could get above 4000 rpms. I tried in 2nd and 3rd gears, but each time it went to 4 grand and its like the fuel or spark is being cut out. It will start sputtering and produces no more power until I get oof the gas and the rpms drop. I just don't know wth is going on!
Old 05-11-2007, 03:08 PM
HuskyRunner's Avatar
What all was it in the shop for to begin with?
Old 05-11-2007, 04:18 PM
Fo-runna's Avatar
Seriously... take it back and tell them that they messed it up.
Old 05-11-2007, 04:56 PM
rimpainter.com's Avatar
It's about 5600 on the 5VZFE. Something is seriously wrong.
Old 05-12-2007, 07:03 AM
Joshs98Runner's Avatar
Have you checked spark plugs and wires? Sounds simple but it could be a start, also check and make sure vacuum lines are all hooked up...sounds odd but the timing belt could be off a tooth maybe? How does it idle and drive other than the cut out at 4k?
Old 05-12-2007, 08:43 AM
mikes984x4's Avatar
It went to the shop to begin with because of a knocking noise that was coming from the front of the motor and power & milage had went down quite a bit. Turns out, the timing belt had somehow jumped and drastically messed up the timing and the balancer on the crank had became loose somehow, causing damage to the crank itself. So all together, it just got a tune up, new spark plugs, wires, new timing belt and new crank. Right now it drives fine, even though it cuts out at 4000. Compared to my cousins rig (97 w/3.4 and auto trans) it seems o.k. Other than that, all vaccum lines and wires are fine. It just bugs the crap out of me that I can't rev it high enough to reach peak horsepower.
Old 05-12-2007, 11:05 AM
YM13's Avatar
well a couple of people mentioned that it could be the timing belt and you just said it went in the shop for a problem with the timing belt so that is most likely the problem area....just take it back to them and show them whats going on...
Old 05-12-2007, 11:06 PM
slus's Avatar
x2
I would have turned around and gone right back.
Old 05-13-2007, 01:06 AM
iholla's Avatar
Its been soing this ever since you drove it from the shop?
Mine goes on past 5K
Williamemslie
14
10-05-2015 09:28 AM
93toyoguy
3.4 Swaps
10
09-18-2015 04:16 PM
Obmi
09-16-2015 02:13 PM
dlaiben
3.4 Swaps
09-03-2015 09:57 AM
Quick Reply: 3.4 Rev Limit?
