3.0----->3.4 conversion, need help FAST!
Old 04-20-2004, 03:58 PM
Question 3.0----->3.4 conversion, need help FAST!
I have a '94 4Runner with the 3.0 v6. The head gaskets let go in late September and it hasn't moved since. I have the oppourtunity to get a '95 3.4 v6, ECU, and tranny for dirt cheap. I've done a little reasearch on the subject, but I need to know what else I need to have to complete the conversion, and I need to know A.S.A.P. If anyone could help me, I would greatly appreciate it. Thank you in advance.
Old 04-20-2004, 04:02 PM
L33T35T 4Runner's Avatar
did they make any trucks with the 3.4 in 95?
maybe the motor was made in 95.... i dont know
Old 04-20-2004, 04:04 PM
shazaam's Avatar
Find a 96 .. b/c they didn't make the 3.4 till then
I believe that the 3.4 first came out in 95.
Old 04-20-2004, 04:06 PM
i know for a fact that the 3.4 didnt come out in the 4runners until 96. maybe it came from a tacoma or like i said.. it was built in 95 and put into a 96 truck
Old 04-20-2004, 04:07 PM
You are correct, just checked the Chilton's. Then I assume it is a '96. Still need the extra info.
Old 04-20-2004, 05:02 PM
mt_goat's Avatar
Are you going to do it yourself or pay someone to do it? These guys will help http://www.offroadsolutions.com/tech...ersion_kit.htm
Old 04-20-2004, 05:05 PM
AverysDad's Avatar
technically 95 1/2 was the first year for the 3.4 but most just refer to it as 95
and this outta help out a little
Old 04-20-2004, 05:07 PM
Plan on just doing it myself. Cant afford to pay someone else to do it.
Old 04-20-2004, 05:11 PM
Cebby's Avatar
Ya beat me to it...
Old 04-20-2004, 05:14 PM
AverysDad's Avatar
check out the link i added to my above post in case you missed it
Old 04-20-2004, 05:18 PM
MTL_4runner's Avatar
The first 5vzfe's came out in 95.5 on the Tacomas, 4runners didn't have them until 96.
The swap is very doable.....the wiring harness should be bought from www.offroadsolutions.com
Old 04-20-2004, 05:20 PM
Crap! So it is only a direct bolt in (mainly) for a manual tranny? That sucks.
Old 04-20-2004, 05:22 PM
Thumbs up
Oh, and btw, a big thank you to AverysDad for actually posting something that led me to some information, and not argueing about when the 3.4 came out.
Old 04-20-2004, 05:23 PM
Not true.....autos will usually bolt up fine, shifting is a problem tho.
Manual tranny make sure you will not have this problem.
Old 04-20-2004, 05:24 PM
You can check out the thread I started a while ago on this:
https://www.yotatech.com/forums/show...3.4+motor+swap
Old 04-20-2004, 05:25 PM
I will have the ECM, and the tranny. Will these bolt up to my existing TXcase?
Old 04-20-2004, 05:26 PM
Thanks to you also MTL.
Old 04-20-2004, 05:29 PM
Another great source of info is here:
Great source for pics and info!!!
http://www.pirate4x4.com/forum/showt...5&pagenumber=1
and here:
Guy wrote up a bit after doing the swap.
http://www.automotivetalk.net/showmessages.php?id=633
More info:
http://www.geocities.com/humboldttoyota/5vzfeswap.html
....and finally my last link:
http://www.4x4wire.com/forums/showfl...5&o=14&fpart=1
Happy reading!
Old 04-20-2004, 05:32 PM
Flygtenstein's Avatar
If you have an auto, the t-case and tranny are not separable.
If you have a 5spd, an adaptor can put the chain drive behind the new tranny or a gear drive or two or three.
Read the ORS page.
If you need these kind of questions answered fast, I think you need to do some more reading.
Quick Reply: 3.0----->3.4 conversion, need help FAST!
