22R-RE, How many Quarts of Oil?
From the Owner's Manual:
http://www.4crawler.com/4x4/4R_TechInfo.shtml#Fluids
4.9 qts. is the official volume, I usually use 4.5 then dump in the other 1/2 qt. then the level starts to get near the add mark.
I've never seen the 4.9 recommendation, but I believe you. Do you think us 4.5ers are causing harm?
The 4.9 figure is directly out of the '85 Owner's Manual from my 4Runner. I think that is a dry fill and I doubt you can drain every single drop from the engine. Better to underfill a little than to overfill. If I do 4.5 qts. it is close to the top mark on the dip stick. My engine uses some oil, so it is usually down to the add line by around 1500-2000 miles.
Toyvana
07-29-2015 10:47 PM
yourrealdad
07-29-2015 11:08 AM
