2002 S-Runner Help
2002 S-Runner Help
I know it's not a 4Runner but some have the same engine [5vzfe].
Anyways, I am helping a friend wrap up a long forgotten project of his and were close to the end BUT I need some help identifying some components and "where it goes to".
I have provided pictures below any help is much appreciated!!
The following are located behind the intake manifold:
On this image the small circle represents the hose that is in my hand
This on is located under the throttle body:
Again thank you guys!!
It would help if I could click and enlarge them. With out going out to my runner the only one I can help you with is the last picture, the line under the throttle body is a coolant line.
the wire harness by the alt goes down to the o2 and transmission plugs
the connectors by the brake booster go to the evap components
the two vacuum lines at the front of the intake manifold, both go to the intake tube.
the vacuum line in the bottom pic goes to the back of the intake manifold and splits off to to other lines at the back.
Your pictures kinda suck.. But thats all I got.
I am confused on your explanation of the picture before the last one[and the one before that], these "ports" seem to be on the valve cover, ONE of them is in a Y format [the 3rd picture from the bottom up, you can see the one hose with the hose clamps and one other port clearly, on the next one you see a closer shot to reveal the 3rd port that is in a Y with the one with the hose].
Thanks for the help guys!! I'll post pictures of the project once it's done.
anniesball
12
09-30-2015 08:09 AM
