2001 Tacoma TRD died rolling and wont start
Old 04-21-2017, 01:16 PM
Texas Trapper's Avatar
2001 Tacoma TRD died rolling and wont start. Swapped relays around and assume they are good, fuse good. Was in process of taking tank out to get at the pump but decided to test pressure first and pressure under hood is 50#. Spins over fast like no fuel to injectors. Found one bad cracked vacuum line on FPR and another on manifold possibly affecting the whole system as well as the fuel pressure regulator, repaired lines and zero. Tank is ready to come out if I can get the gas siphoned out but not gonna if problem is under hood.. I might add the gas in my pressure test line did not retreat back to tank.
Old 04-21-2017, 01:55 PM
Fossilized
Staff
dropzone's Avatar
I fixed your thread title so it was more relevant to your issue...'rick' probably would not have for you the help you need
flg8r22's Avatar
Spins over fast like it jumped time?
Old 04-22-2017, 01:09 PM
ZUK
ZUK's Avatar
If the timing belt actually broke then engine would appear to spin very freely.....
crank will be turning but the cam shafts won't be.
Old 04-22-2017, 01:16 PM
ZUK
ZUK's Avatar
If yours is a 3.4L V6 and the motor has over 250,000 miles and is still on the original belt.....then there's a fair chance it decided to snap.
Old 04-23-2017, 12:46 AM
wyoming9's Avatar
Red face
Quite easy to pull the top timing belt cover off .
Just slide the Top hose clamp front and remove the bolts.
Then the Mil should also be tripped with a Cam sensor code PO340 if the belt did fail along with a few others
Old 04-26-2017, 08:18 AM
Thanks guys, belt did not break. There was a ton of caked up crud in there from I guess a water pump leak. Never dripped to concrete and been leaking for years. Water pump rubber seal was wrapped around its own shaft. So much caked up junk going on in there it filled the crank gear and jumped time 60-70 degrees. I took some pictures if anybody needs to see.
Old 04-26-2017, 11:41 AM
wyoming9's Avatar
Red face
Be great to see just for reference !!
Old 04-27-2017, 01:20 AM
all from leaking water pump.
Old 05-02-2017, 06:37 PM
ZUK
ZUK's Avatar
Quite a mess there
Old 05-03-2017, 12:49 PM
yep big mess. Got parts in today and wrong water pump in the kit.
No heater hose connection on it.
Old 05-03-2017, 02:25 PM
TheDurk's Avatar
That's not a heater hose. It's for the oil cooler. Might help you to know when talking to supplier.
I suspect it didn't just jump time, but that crank sprocket is not driving belt at all. It's probably stripped of its cogs. Water pump leaked, coolant softened belt, then pump seized, and belt stripped, killing engine.
StewFi
12-06-2016 10:45 AM
Slayz
12-04-2016 08:56 AM
Audrienne
10-04-2016 12:53 PM
rustyShake
14
08-24-2016 12:23 PM
tomstin
11-25-2002 06:44 AM
Quick Reply: 2001 Tacoma TRD died rolling and wont start
