1999 Tacoma 3.4 belt squeak
Old 11-04-2015, 10:28 AM
Matt93eg's Avatar
Hey guys,
Have a 1999 Tacoma 4x4 5 Speed with the lovely 3.4. Almost 275,000 Miles
A little while back I noticed one day that it sounded like one of my drive belts was squeaking. Not a slip type noise but a squeak.
Today I heard it and it was doing it louder and was really annoying the piss out of me, I cannot stand to hear belt squealing/squeaks. I stopped and popped the hood. Looked closer this time and noticed the water pump pulley had a slight wobble to it. I switched the engine off and looked again, I could see one spot on the pump where the pulley was making slight contact with the metal thus causing this squeak sound. I got the truck home and I just pulled the Alternator and P/S belt off, removed the fan and the pulley to get a closer look.
Now with the belt pulley that the ALT and P/S belts ride on off I can spin the actual circular piece that it bolts onto and it wobbles, not spinning true by any means.
I did some searching and found something out that this part is the fan support bracket and something about a bearing and it being expensive but I couldn't find any clear info.
Can anyone help me further so I can get this resolved? I imagine going down the road at 2k RPMs and having this bearing or whatever fail completely would be BADDD news. Makes me cringe thinking about it.
Old 11-04-2015, 12:53 PM
TheDurk's Avatar
You are talking about the Fan Pulley Bracket (Toyota p/n 16307-62011), popularly called the fake or dummy water pump. You can get the OEM AISIN part on Amazon for a good price, like $138 (AISIN p/n FBT-004):
http://www.amazon.com/Aisin-FBT-004-Fan-Pulley-Bracket/dp/B0031GE6X2 http://www.amazon.com/Aisin-FBT-004-Fan-Pulley-Bracket/dp/B0031GE6X2
RockAuto.com probably carries the Aisin as well. Dealer list is like $539 for the same part in a pretty red box.
Any timing belt DIY will show you how to R&R this part.
Old 11-04-2015, 03:03 PM
Matt93eg's Avatar
Thank you very much! I appreciate it greatly. Dummy or fake water pump is a good name for it cause it sure looks like it. I looked up from that Aisin part you listed above and then found it for $115 on ebay. Not to bad and i am sure it is the original bearing so no wonder it is bad after 275k miles. I may go ahead and do the Timing Belt, Waterpump and all tensioners and drive belts while in there.
Again, thank you!
Old 11-05-2015, 03:54 PM
Pipsisiwah's Avatar
@OP
On my 3.4L engine the water pump pulley is behind the large black plastic cover and is driven by the timing belt. One cannot see it until that cover comes off, so I think you prolly mistook some other pulley for the water pump pulley. Say again which pulley was wobbling??
Old 11-06-2015, 02:30 AM
Matt93eg's Avatar
Originally Posted by Pipsisiwah
@OP
I had initially gotten confused. I already knew the Timing Belt drove the water pump but how I got confused I don't know.
The pulley that is wobbling is the top pulley at the cooling fan and the Alternator and Power Steering belts both use it.
Old 11-06-2015, 08:42 AM
Pipsisiwah's Avatar
Hmmm. Sorry, can't help you there. When I removed that support bracket last August I don't recall any movement (other than rotary) in the pulley so I just reused it.
Old 11-11-2015, 05:20 AM
Matt93eg's Avatar
I am about to order the fan support bracket. I had to go back into Ebay and search for that Aisin bracket again and found it but below the listing was another fan support bracket but instead of a price of $115.00, it was $40.00. A HUGE difference. I assume this $40.00 part has to be made out of super CRAPPY metal but if it would work I would sure hate to spend another $75.00 on that Aisin part. Any body have experience with the CHEAP one? Both parts are listed below.
Cheap one: http://www.ebay.com/itm/95-04-TOYOTA...VRDDDw&vxp=mtr
Aisin: http://www.ebay.com/itm/Engine-Cooli...9VlXYI&vxp=mtr
Old 11-11-2015, 08:52 AM
Pipsisiwah's Avatar
I don't drive my TRD much but when I do it's at least a couple hundred miles away from home when I BEGIN my off-road driving. From there I may be off road beginning 800 miles or so away from home. I drive alone so I demand genuine Toyota parts and in your case, the genuine Toyota part. I wouldn't pay $500+ for one though, so I would go with the $115 part. The $70 savings doesn't go very far when you are disabled due to a cheap-ass part...
Old 11-12-2015, 12:04 AM
wyoming9's Avatar
Red face
I have not pulled one of these off yet .
Is it possible to just replace the bearing.
Now I am curious !!
Old 11-13-2015, 09:45 AM
TheDurk's Avatar
I agree. It's a pretty mission-critical part and I don't see how you could make it for $40 without using a cheapass Chinese bearing and inferior metal in the casting. Go AISIN for $115.
If $$ are really short, Amazon has some warehouse Aisins in damaged packaging for $51.78. It says used, but I think that has to be just because of the box.
http://www.amazon.com/gp/offer-listi...condition=used
Old 11-13-2015, 01:44 PM
rworegon's Avatar
Wyoming, don't think I've ever seen just the bearing replaced on them. I looked at it years ago and ended up buying a new AISIN.
Old 11-16-2015, 12:10 PM
Matt93eg's Avatar
Thank you guys for the responses. Been busy so I haven't had time to respond. Bought the Aisin part for 115. Wish I would have seen TheDurks response sooner so I could have checked amazon but no big deal. It is suppose to be here Thursday so I will get it changed out this weekend before that darn thing grenades and causes my cooling fan to grenade something else.
MAINETOY
01-06-2016 11:48 AM
Waylayer
11-25-2015 06:14 AM
Marsheen
11-06-2015 07:14 AM
adamthedroog
11-02-2015 08:02 PM
vandert
10-18-2015 07:37 PM
Quick Reply: 1999 Tacoma 3.4 belt squeak
