1997 4runner wont crank
Old 03-03-2010, 02:28 PM
974runnerhelp's Avatar
I just baught a 97 toyota sr5 4runner its automatic 3.4l 4x4
the runner had a bad motor so i baught one from the junk yard swaped it in,cranked it over but nothing happens...i turn the key over no starter,no fuel pump,and no spark, but get this whenn i turn the key over 4 times the stock alarm comes on beeps once and the light stays on, i replaced the relays under the hood,replaced the ecu/computer,replaced the ignition switch and ignition module
what could be the reason why it wont start?
no spark
no fuel
no crank
one thing i did do is jump the starter from the relay and it cranks but no spark or fuel.
Old 03-03-2010, 04:40 PM
brian2sun's Avatar
Check all fuses.
Old 03-04-2010, 02:58 PM
I already did that,Its mind bogling
this is what ive done
-replaced the ecu
-replaced all fuses
-replaced all relays
-checked the ground wires
-unhooked the battery and hooked it back up
-unlocked the car from the outside twice
Old 03-07-2010, 07:35 AM
Ron Helmuth's Avatar
was the replacement motor also from a 97 with auto?
see where I am going with this?
There are subtle differences between flights of the 3rd gen Runners (96-98) (99-00) (01-02)
I'm no mechanic and not pretending to be. But the possibilities are endless.
Old 04-18-2012, 10:21 AM
Huntermarx97's Avatar
Im having trouble with my starter also.. i had my friend hit it while i tried cranking it over, he thought he'd help me by ppoking some wires with a screwdriver.. After i replaced all the fuses he popped, and charged my battery, I finally got Power back to my dash. Now though, whenever i turn it over my battery goes from 13 volts to 4.. Then slowly back up. Any ideas on the Problem???
Old 04-18-2012, 01:54 PM
tantacoma's Avatar
Wild ass guess? Bad starter. Replace it.
Old 04-18-2012, 06:52 PM
trx125's Avatar
Did you make sure the crank and cam position sensors are hooked up? Make sure all the wiring harness grounds are tightened down, not just the battery and fuse block grounds.
Old 04-19-2012, 04:24 AM
jeremy9allen's Avatar
Originally Posted by 974runnerhelp
when i turn the key over 4 times the stock alarm comes on beeps once and the light stays on
Sounds like it is in a theft mode of some sort.
Old 04-19-2012, 07:12 AM
Oh Wow!!! thanks so much!! Of course I've replaced it. Still Wont turn over
Old 05-01-2012, 07:48 PM
Peacefrog53's Avatar
Sound like what I ran into. But I pulled a bone-head move by not hooking up the grounds.
Old 05-03-2012, 06:04 AM
Keith122's Avatar
I swapped the engine in my 97 4runner and had the same issue, no crank, no spark or fuel. There is a large electrical connector behind the glove box that snaps together, and has a lever that pushes the wires together and locks them into place. I forgot to use the lever. Once I figured this out, everthing worked like a charm. Maybe you should check this too.
Keith
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
sandyota
02-04-2021 11:16 AM
redneck17
07-17-2015 07:44 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: 1997 4runner wont crank
