1996 Toyota Tacoma 5spd J TCASE 4wd will not disengage
Old 01-17-2016, 06:47 PM
Bryndenhunter's Avatar
I am having troubles disengaging 4wd in my truck I have narrowed it down to the VSV not getting power to swap the actuator. I have the 2wd vacuum hooked up to direct engine vacuum to keep it from going into 4wd.
I have replaced the tcase switch, the front actuator switch and also the "transmission relay" in the front passenger kick panel. I am out of options and I don't know what to do short of putting both the VSV valves on a rocker switch.
Thank you in advance for helping me out.
GuitarMike
11-09-2015 11:45 AM
nekchris
10-27-2015 12:22 PM
hexrain
10-25-2015 08:29 PM
yotapwru
Washington
10-22-2015 09:08 AM
Obmi
10-20-2015 05:22 AM
Quick Reply: 1996 Toyota Tacoma 5spd J TCASE 4wd will not disengage
