04 Taco - Periodic tentative starting....
04 Taco 3.4, 5-sp, 3 weeks old, 900 miles to date.
1 out of every 10 cold starts is, well, not soo smooth.
At the point when it would normally catch and fire it kinda stumbles, and then requires another 1.5 seconds of cranking.
I turn the key to the on position for a few seconds to let the fuel pump pressurize and then turn to start. I usually hold it till it starts, but as mentioned it not always smooth. Sometimes when its not smooth I stop cranking too soon and it doesn't start. I try it again and it starts smoothly as normal.
Don't think its like the truck is shaking violently and won't start. Its not. Just sometimes its cranky.
Its not really a bid deal, just seems odd.
Once started, it runs great.
Any ideas?
Similar experiences?
Thanks in advance
Any ideas?
Thanks in advance
I really dont think its anything to worry about. Basically it sometimes just takes an extra second or two to start right? Mine does the same thing (1999 3.4 Taco, 72,000 miles). It scared me too at first cause my F-150 before it didnt crank at all....just started right up. Its just something you gotta get used to, just the way the engine is designed I suppose. I remember reading other posts about this and it seems perfectly normal.
i have your exact truck except mine has 5000mi. i get the same thing.
my mom has an 04 Accord that does the same thing once in awhile and the dealer told her it was something to do with a self diagnostic, BS? i don't know
This is a common problem in '04s of all kinds. Foreign and domestic. The general fix from the american car companies for this is to make a TSB to reflash the PCM and that seems to fix the problem for the most part. You might shoot an email to Yota and see what they say about having something in the works.
Josh
Josh
This is actually a common problem with the 3.4L Tacoma's. There is a pretty large thread about it on the TTORA message board. Toyota has denied that the problem exists. I haven't experienced this yet, but I only have 470 mi. on mine.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
83yotastockR
11
11-10-2015 06:54 AM
Toys4parts
09-26-2015 01:56 PM
sonorn67
09-19-2015 05:39 PM
