rustED's 87' 4Runner Build
#261
I should be getting my Crater Maker dimple dies this week. going to use them for the mounting holes for the side panels, I think it would give it a cool finished look with the flanged button head allen bolts I'm going to use.
#265
Love the tools you have bought/made/modified so far. And I think your panels and doors are a fantastic idea. I'm looking forward to what you do with the doors.
#266
Thanks Robb!
Thanks Terry, I'm liking it, it has already come in handy!
Thanks! I've never tried shipping anything even close to that size before, trying to get them shipped without getting bent might prove to be to much of a challenge...I'll have to look into it further.
Thanks! I hope to start on the doors soon!
#267
Worked on the driver side panel a little more today, since I was using the electric shears anyway decided to cut out the tailgate cover/panel. Don't know if the sheet metal will work good for the tailgate, climbing in out might dent it? I plan on running beads lengthwise to further stiffen it up and for asthetics.
^^^my helper for the day, he wanted to try out my new electric shears, he did a good job and cut right on the line! The sun was in his eyes, lol.
^^^made a cardboard template
#271
Thank you!
Thanks Tony. I hope I got the right size flanged button head Allen bolts and the fit correctly with the impression left by the Crater Maker dies, guess I'll find out! I was really impressed by the latches I bought. As you turn them, they automatically click into place, almost feels like a magnet, it does this when turning in either direction. There is enough resistance that it should prevent vibrations from causing the latch from loosening and the door for opening accidently. I really want to get a flat dimple die that leaves a recessed area and mount the latches in the recessed area left by the die, but I'm out of funds for now, so will probably just flush mount them for now. Here's the dimple die I want:
I'm wondering if I could make one out of a piece of tubing and maybe an old socket that fits the inside diameter of the tubing, I might try that tomorrow...
Thanks CamTom!
Thanks CamTom!
#272
So I decided to try an make a recessed flat dimple die before going to work today.
I basically welded a nut to the bottom of a square peice of plate steel. Then I welded a peice of tubing to the other side. Then threaded the bolt up though. I just happened to have the right size flat washers, so I used them as spacers and stacked them up inside the tubing until I got the depth I wanted
The 1" socket fits the inside diameter of the tubing
first try went a little to deep, almost worked as a hole punch
çut halfway around, I also forgot to trace the socket with a sharpie so it wasnt centered with the hole
second try, i went a little shallower, but I got it centered good this time
#275
Ed, looking good man, I think you'd have some paying customers for just the doors. Excellent fab skills.
#278
Fantastic. Making that homemade die worked nicely. A little bit of thought goes a long way and saves a bunch of money. Im interested in buying the RustEd tools for my shop. When do they go on the market?
#279
#280
Thanks you!
Thanks everybody for all your compliments and encouragement I really appreciate it! When I started this project it was more for practice to try out my beadroller and my press brake and get a feel for how they work. I probably should have used 20 gauge, maybe thinner since when I put the raised bead(s) in the panel it's going good to stiffen them up alot. I'd really like to make the doors for those of you that are interested, but I hadn't planned ahead for that. I think the 18 gauge I'm currently using is going to be to heavy to make doors out of for those who want to use them with their stock plastic side panels. I weighed my door and it came in at 2lbs, (the factory plastic door weighs about 10oz). If I made the vents like Spacejunk suggested I could shave a little weight off, but I'm afraid they may still be to heavy. My concern is that the extra weight in the middle of your plastic side panel might cause more vibration and possibly Crack your already fragile 30+ year old side panels.
I'm thinking I'll need to go with a thinner gauge sheet metal or if cost effective maybe aluminum. What do you guys think? I haven't ever priced aluminium sheeting, but I have a feeling it will be expensive. I'm going to continue working on this project and look forward to some input from you guys on how I should proceed, thanks again!
Ed.
