Dropzone's 1994 4runner Build AKA: Project Recycle:
Old 05-12-2017, 04:50 PM
  #481
Fossilized
Staff
dropzone's Avatar
4runner's CEL came on a few days ago. Go to pull the codes, since it is pre-OBD2 so you have to jumper the diagnostic port. Found the EGR temp sensor unplugged(right next to port, plugged it back in, pulled code sure enough code 71(EGR fubar). Pull EFI fuse to reset, CEL out..i love free fixes, new sensor runs about $150.
  #482
Fossilized
Staff
dropzone's Avatar
Old 05-13-2017, 01:05 PM
  #483
habanero's Avatar
Nice catch!
Old 05-15-2017, 11:14 AM
  #484
Radchadtrinidad's Avatar
i saw that you used 4' TG leafs up front and took a leaf out. i love your stance and that is my goal to sit where you are. with that being said, would you reccomend the 3'' lift? or will it start to sag vs the leaf pulled 4''.
Old 05-15-2017, 11:40 AM
  #485
Fossilized
Staff
dropzone's Avatar
Originally Posted by habanero
Nice catch!
Thanks Hab!
I actually ended up putting the leafs back in. I just haven't had time to pull it again to see what happens. This springs were on my 81 for 8 years, to be honest I thought they would have been sitting lower.
Depending on what front spring hanger you use (i used a low profile hanger from Low Range Off Road) with 4" springs you could end up pretty high. To be honest it is up to you. I would like to buy brand new 3" springs
here is a pic of 85toyman's 94 (he did my SAS for me) he used a sky's front hanger and 3" trail-gear front springs to give you an idea. Hope it helps
Originally Posted by 85toyman
Old 05-19-2017, 06:52 PM
  #486
Fossilized
Staff
dropzone's Avatar
after having a spring time flu I finally felt up to getting vertical and had some time so tackled replacing the master cylinder and brake booster
when you are short like me this thing from Harbor Freight comes in handy
the hitch mounted vice has been proving it's worth a lot lately. Bench bleeding the master cylinder went off with out any issues
When i pulled the old master cylinder there was quite a bit of corrosion inside the brake diaphragm it so I went ahead and replaced it too.
instead of doing the usual zip tying the LSPV rod up out of the way I went with a small bracket idea that 85toyman had mentioned works like a charm
with pretty much all new brake parts with the exception of the backing plates and hard lines the 4runner stops like a dime now.
Old 05-19-2017, 07:26 PM
  #487
rattlewagon's Avatar
^ Thats a great idea with the break rod. I always zip tied it too the underside of the bed. Haha. Yours is much classier!
Old 05-20-2017, 04:11 PM
  #488
Fossilized
Staff
dropzone's Avatar
Thanks rattlewagon, i remember it being wired up on my old 84. I think this will do the trick, I'll probably cut the rod down next time I am crawling around under the back
swapped out the Trail-Gear shackles that were pretty close to hitting the front body mount with the truck sitting still
shackle angle was pretty crappy due to using this X-O Fab frame brace with integrated steering box mount, with it you are limited to how far forward you can push the front spring hanger as the steering box mounts in the stock location.
it will be interesting to see how the Sky's Delrin spacers treat the spring bushings, with the steel spacers provided by trail-gear the bushings don't have a steller service life.
Sky's Off Road Boomerang shackles installed
Old 05-20-2017, 05:27 PM
  #489
flg8r22's Avatar
Nice Robb. Looks like the time you were down with the flu has given you a lot of motivation to get stuff done
Old 05-20-2017, 07:17 PM
  #490
Fossilized
Staff
dropzone's Avatar
For reference use: Oil Pan conversion and A340H info
Originally Posted by defrag4
yep, for anyone else that runs into this issue.
Left is T100 2wd pan, right is the 3vze 2wd pan
you can see the small dip here in the pan which is needed to clear the crossmember
[img][[img][/img]
and with the 3VZE pan on the 3.4L motor, the pickup will not clear the pan. So I had to take the 3VZE pickup and swap it over. But like you say the pickup hits the baffle, so needed to cut a hole in the 3.4L baffle, then you can access a bolt hole and secure it up there.
The second leg of the 3VZE pickup does not have a bolt hole on my 96 T100 3.4 to bolt up too, so I just chopped it off, seems fairly secure still so I think I will be fine.
You can see here with the baffle removed where the 3VZE pickup can bolt up, the Red square has a bolt hole, the yellow leg does not and needs to be removed.
Cut a hole in the 3.4L baffle with a cutoff wheel and now we can bolt up the 3vze pickup to the 3.4 block
Automatic Transmission info for 3.0 with Auto
from this thread on Pirate
Sounds like the 3.0 with auto has an A340h
http://www.pirate4x4.com/forum/toyot...sues-faqs.html
Originally Posted by 4runnerx3
If
Old 05-22-2017, 03:55 PM
  #491
OilTrash's Avatar
It does. I just got done tracking down trans and tcase parts for my wife's 94 3.slow build. it's a curse and a blessing because the A340H trans and tcase have to stay together and there isn't any way to substantially upgrade things unless you swap them both out. I look at it as a way to keep me from giving the wife enough power to break stuff, but it's going to be boring for me to drive.
Old 05-22-2017, 04:06 PM
  #492
OilTrash's Avatar
no idea why I double posted, probably because my latest home brew is ready to drink. My Toyota buddy is over and he said ditch it and toss a stick in it,
"the 340h sucks and will go buy buy at some point, it might as well be during the swap"
figure 14 years as a mechanic for Toyota dealerships his opinion was worth passing along.
Last edited by OilTrash; 05-22-2017 at 04:21 PM. Reason: No idea why it posted twice
Old 05-22-2017, 04:10 PM
  #493
ericwudi0830's Avatar
nice job
Old 05-22-2017, 05:12 PM
  #494
Fossilized
Staff
dropzone's Avatar
I'll cross that road when I come to it, so far I like the auto. I do plan on fixing half the equation and using this kit from Low Range Off Road to build something like this with duals from my last truck
If I end up doing a 5 speed conversion I guess I will have to order one of these
Old 05-31-2017, 05:06 PM
  #495
Fossilized
Staff
dropzone's Avatar
Time to do legal stuff - tire coverage
got pulled over saturday for my tires sticking out beyond the fenders and no mudflaps. Told the deputy I would get it fixed in the next few days, he said no problem.
Pulled the old mudflaps from the 81 off the shelf and looked at what I had to work with on the 4Runner. A couple of pre threaded holes...hmmm
looked at the luggage rack and a plan started to come together
two threaded lugs and removable mudflaps
tomorrow i'll see what i can do about flares
Old 05-31-2017, 06:53 PM
  #496
habanero's Avatar
Great re-purposing yet again dropzone. I like the easy grasp connectors, good idea. Nice touch with the LSVP rod bracket too.
There's some kinda spring nasty going around here, too. Unlike you, 5 weeks of drowning in my own snot did not inspire me to do anything at all. At least it wasn't flu-bad. Hope you're back to tip-top.
Old 06-01-2017, 07:26 PM
  #497
Fossilized
Staff
dropzone's Avatar
Thanks Hab, been feeling pretty good other than allergies...Hope you are feeling better soon!
On to Operation Keep the Law Happy part 2
Added some flexible rubber fender flares compliments of Amazon prime
Also pulled the steering wheel cover off and found some nastiness, found a good deal on the Wheelskins cover
Went to get gas and the gas door wouldn't open. Popped it open and found the lower hinge mount had popped lose, slapped some epoxy in there and clamped it, works like a charm ..for now
wiped up the excess, looks like crap but who cares on the gas door
Old 06-02-2017, 06:01 PM
  #498
Fossilized
Staff
dropzone's Avatar
So the missus agreed with me that the flares came out looking like crap so got the go ahead to order a set of flares
https://www.junglefenderflares.com/t...er-hilux-surf/
Should have them in time for a Father's day install
I busted out my $64 Harbor Freight Booger Splatterer (aka flux core welder) and used electronic snot to mount some light tabs
I picked up these eBay 50w Light Cannon knock offs last year. Nice thing is you can use Vision X filters on them so spots can turn into floods with one set with out the $500+ price tag
Old 06-02-2017, 06:09 PM
  #499
flg8r22's Avatar
Robb those flares look like a quality product. Do you know if they are paintable?
Old 06-03-2017, 07:20 PM
  #500
Fossilized
Staff
dropzone's Avatar
thanks Tony, I tried to find out about the paint on their website but did not see anything. I guess I will find out in a couple of weeks.
Was trying to find a simple way to sort of hide the body line that was opened up when I swapped bumpers..dunno but it so have to do
​​​​​​​Name:  20170603_150858_zpsiepy4c1x.jpg
Quick Reply: Dropzone's 1994 4runner Build AKA: Project Recycle:
