86 4runner
86 4runner
Just picked it up last week has nice interior new carpet put new shocks, steering stabilizer inner and outer tie rods new ps pump and idler pulley and belt. Still have work to do
Looks like a great truck, SR5 too!
Nice!
Would you pls sell me your SR5 cluster? LOL!
Best wishes with the restoration. Let us know how we could help.
Speaking of cluster I gotta pull it andfix the temp guage this weekend ive got about 7 tabs open and saved with tech write ups for all the common problems and fixes. This site is the best by far. Ill post more picks as i get into it.
Had an issue with the warn manual locking hubs it has on it the warn springs inside hub were worn out not enough pressure to keep 4wd engaged fully. After lookin furiously for just a spring kit for the hubs i went to lowes and found some cheap thick washers that were almost same size as springs put 2 inbetween spring and gear it pushes toward the back of the hub and reinstalled worn out springs toward to front of hub. Now hubs work flawlessly lol. Just didnt wanna crank out 200 bucks for a whole new hub set when springs are the only problem.
Update: New thermostat, injector seals installed, rear main clutch flywheel waiting to go in this weekend along with front calipers rotors and pads. Coolant temp guage is fixed just disassembled and cleaned corrosion and reassembled with no issues. Soon new tires and rims 🤘🤘🤘
4RunnerFreak12
13
12-05-2016 11:10 AM
Ruger2011
11
10-08-2016 01:06 PM
