1992 4runner build up
Old 11-22-2014, 10:59 AM
sphealy's Avatar
Got the 4Crawler 2 inch body lift installed today. It took longer than it should have but it was cold and I was moving slow. At least its done though.
Old 11-22-2014, 11:01 AM
sphealy's Avatar
Old 11-22-2014, 05:33 PM
Roark's Avatar
What's the story on those rims? Pretty slick
Old 11-22-2014, 05:59 PM
sphealy's Avatar
http://www.jegs.com/i/Detroit+Wheels...FXES7Aodf1kAFg
Yeah I liked them too. They were on it when I bought it with 31s. Paid 1000 for the whole rig. Came with a blown headgasket too so I've never driven it. Just hope they hold up to trail use. Jegs sells them.
Old 12-26-2014, 01:11 PM
  #25
sphealy's Avatar
Finally got the auto wire harness converted with the new manual plugs today. Already ordered a manual computer just waiting on it to get here. No I need to figure out the rest of the wiring. I know people say its not that bad I'm just not putting it together in my head very well. Hopefully it will start to make sense sooner than later.
Old 12-26-2014, 06:32 PM
  #26
voodoo556's Avatar
Right on ......Good buy on the Runner!
Interested to watch your build.
Old 12-31-2014, 03:53 PM
  #27
sphealy's Avatar
Computer came in so im running out of excuses. Going to try and mod the exhaust crossover this weekend.
Old 01-01-2015, 05:12 PM
  #28
rustED's Avatar
Nice build so far. I know how you feel, I bought my runner with a blown head gasket and never drove it till after I did an engine swap and a sas, lol, the wait will be worth it in the end!
Old 01-01-2015, 05:33 PM
  #29
sphealy's Avatar
Got the crossover disassembled today. I have to wire the dedicated outlet for my 110 welder and finish disassembly on another 3.4 sitting on my engine stand before I can try and weld it back together. Hopefully I will get the outlet and disassembly completed Saturday. I now have another project to deal with as well. I just purchased my 91 4runner back from stepdaughter. It's a bit worse off than it was. Her last accident (guardrail) messed up the steering. Left hand turns are normal but it takes an act of congress and some steroids to turn the wheel to the right so I have to figure out what got bent and fix that but at least she is ok and the damage is minimal.
Old 01-02-2015, 02:37 PM
  #30
4x4YOTA's Avatar
Originally Posted by JasonYota
You drove that on the street with only two lug nuts holding the tire on?
the truck was still jacked up i just stopped to take a picture but I installed all 24 lug nuts before even putting my tools away
Old 01-31-2015, 07:45 PM
  #31
sphealy's Avatar
Work has been slow because I HATE working in the cold but I got a little progress made today. Cleaned up the engine bay a little and pulled the obd2 plug and 3.4 cor off the donor. I keep going back and forth if im going to build super low budget or do alot of preventive spending like new clutch and other hundred dollor hundred dollar there items. Ill likely just go the budget route since I want to get this one up and running so I can start on the 3.4 and sas on the 91 4runner.
Old 02-02-2015, 05:00 PM
  #32
sphealy's Avatar
Note to myself of things to be done/when completed in no real order
Exterior
**2in body lift-installed 11-22-14
1.5 inch ball joint spacers-purchased waiting to be installed
manual hub/ADD delete-purchased hubs
coil spacers-purchased waiting to be installed
shocks front/rear
clutch master cylinder
clutch slave cylinder
idler arm brace
upper and lower ball joints
front brake inspection
rear brake inspection
front/rear diff fluid change
transmission gear oil change
**fuel filter** completed 4/24/16
tires 33s or 35s?
mount air box possible snorkel
diff breather extensions
Interior
clutch pedal bracket brace https://www.yotatech.com/forums/f116...fatigue-32667/
rear window regulator mod https://www.yotatech.com/forums/f2/p...92/index2.html
head unit
speakers
Engine Swap
**convert 3.4 auto harness to manual-completed
conversion harness-in progress
**timing belt**completed 3-16
**water pump**completed 3-16
**spark plugs**completed 4-24-16
**flip fuel line**completed 4-24-16
**3.0 oil pan onto 3.4**completed 3-16
**tac mod-completed 2-2-15
mount evap box https://www.yotatech.com/forums/f160...85/index4.html
battery relocation
**battery cable for relocation**completed 3-16
AC??? https://www.yotatech.com/forums/f160...4-swap-251179/
power steering hoses
**rebuild power steering pump** completed 3-16
**Determine which alternator to use and mount**completed 4/16 used 3.0 alternator
**exhaust crossover** purchased ORS 4-16 http://www.offroadsolutions.com/prod...rossover-pipe/
oxygen sensor
exhaust
Old 02-03-2015, 03:10 PM
  #33
toyrunnerns's Avatar
I am going to watch this build. I hope to do the same thing in the near future
Old 02-08-2015, 03:46 PM
  #34
sphealy's Avatar
Finally got the 3.4 on the engine stand to start the preinstall maintenance
Old 02-08-2015, 03:49 PM
  #35
sphealy's Avatar
The engine appears to have had regular maintenance. The timing belt looked newish but I don't believe they R/R the water pump. I am just going to do the timing belt/water pump so I have a starting reference point. It appears the rust on the exterior only started after the donors rollover because it all appears to be surface and not as bad as I had previously thought.
Old 02-10-2015, 03:51 PM
  #36
924runner17's Avatar
Ive been wanting to do the 3.4 swap soooo bad
Old 03-22-2015, 04:14 PM
  #37
sphealy's Avatar
Not alot new but I have collected some parts. Got some manual hubs I'm cleaning/rebuilding, some fj80 rear coils and ome torsion bars on the way. Still trying to figure out which shocks to go with. I finally made my mind up to run 33x12.50x15s on this one.
Old 06-28-2015, 09:52 AM
  #38
sphealy's Avatar
So you know its been to long since you worked on your project when you lift the hood and find an abandoned birds nest and a wasp nest under the hood. Guess I should get busy again.
Old 03-08-2016, 05:46 PM
  #39
sphealy's Avatar
So I have finally made some headway on the old build again. I have the conversion harness 85% completed. Tore most of the 3.4 down and I was pleased to see the inside of the engine is in much better shape than the exterior. I had hoped that the exterior looked rough
due to the accident and it seems thats the case.
Old 03-09-2016, 03:45 PM
  #40
sphealy's Avatar
Got the oil pan pick up tube, oil pan, and valve covers cleaned and installed today. Waiting on the mail for the knock senor pigtail before I can reinstall the intake. Ended up getting lucky all the exhaust valves were between .013 and .014 so I didn't have to make any adjustments there. That was a nice surprise.
Quick Reply: 1992 4runner build up
