1984 Toyota Pickup 4x4
Old 04-19-2017, 07:13 AM
  #261
Staff
Terrys87's Avatar
It is always nice to have the parts available to fix another truck. Sounds like a cool find.
Old 04-19-2017, 08:00 AM
  #262
bootscootboogie's Avatar
I'm fortunate that I parted out the white 85 to the point that I did, because it ate up a huge chunk of my initial investment and I still have the axles, the transmission and transfer case, I believe I have around $150 in all of that and the cab. I'm anxious to see how good the truck runs and the general condition. Who knows. May end up building it instead of my 84. I know engine parts are fading into mild obscurity for 84- engines. I think for a long term truck, the 85+ block and head are a safer bet. Terry I love that 76 Ford! It's gonna be so cool when it's done. You can't beat old fashioned American POWER.
Old 04-20-2017, 01:04 PM
  #263
Truck is starting to run "warm" in the evening on the way home. It will not overheat, but the temp gauge is about 25℅ higher than usual. I suspect either the head gasket or the radiator as EVERYTHING else cooling related is brand new. Parts store wanted $38 for a head gasket. Rockauto got me a felpro for $20 shipped. I'm gonna take the radiator to a local repair shop and get it hot tanked because I don't think it would cost as much as a new radiator. But if I have to buy one whatever. Not getting one with a plastic tank. Low range has an all aluminum for a decent price. Until then I'm riding with all the windows open and the heat on blast
Old 04-20-2017, 01:37 PM
  #264
gsp4life's Avatar
Before you slap that hg in, you might want to shop around. Fel-pro makes some really good gaskets, but in my opinion their 22r hg should be avoided. Mine failed before the 40k mark and the head was machined flat. Block deck was measured and fell within spec. It was reassembled by my uncle who maintains a bus fleet and I'd trust his wrench skills with my life. If you're not into the slipper plate design (Toyota and Engnbldr) there are some graphite ones that some guys like a lot.
Old 04-21-2017, 02:07 AM
  #265
arlindsay1992's Avatar
I'm going to second the motion to avoid the aftermarket headgasket. The OEM one only runs about $45 as of about 2 years ago when I replaced mine. I've done two 22RE head gasket jobs on my trucks. The OEM gaskets last. Had to replace a head gasket on a remanufactured engine after it had only 40K miles. No idea what brand they used but it was blue material and not Toyota.
Old 04-21-2017, 05:40 AM
  #266
I cannot have two knowledgeable people tell me something and ignore it. @#&"&$##$___++-&!!!!! I'll order an OEM one. I've had great success with everything felpro that I've used so that's the only reason I bought it.
Old 04-21-2017, 06:07 AM
  #267
gsp4life's Avatar
I'm knowledgeable? Wow can't wait to tell wife the bad news. lol.
By anything I've heard experienced mechanics say, Fel-pro has a good reputation especially on domestic engines. Something weird must've happened in the office the day they designed the little Toyota hg and then for some reason never redesigned. If you give it a quick search, you'll find too many of the same story, regardless of the prep work done or not done: they soon start leaking between the 3rd and 4th cylinders. The gasket material also appears to rapidly break down near the coolant passages. Mine did both.
Old 04-21-2017, 01:51 PM
  #268
Old 04-21-2017, 04:29 PM
  #269
Lons81's Avatar
If you decide to sell those outside mirrors, I'd be first in line. Just sayin
Old 04-21-2017, 05:23 PM
  #270
Didn't even look at the odometer until I got home but if this is true.... whoa!
MORE TO COME I GUESS
Old 04-21-2017, 08:46 PM
  #271
gsp4life's Avatar
Nice original color and decals. The PO did a good job flipping it over. Looking forward to seeing the repair work!
Old 04-22-2017, 12:58 AM
  #272
A tree fell on it!
​​​​​​first things first, taking the parts truck apart, pulling its trans, then this one. Perfect time to install a transmission and body mounts.
Old 04-22-2017, 04:06 AM
  #273
(fggghhhjjjbxx
Old 04-22-2017, 07:45 AM
  #274
flg8r22's Avatar
Dang it Lon. You beat me to it haha
Old 04-22-2017, 07:46 AM
  #275
flg8r22's Avatar
Bootscoot, you are in the perfect part of the country to start collecting trucks. Lucky dawg
Old 04-22-2017, 12:05 PM
  #276
Old 04-22-2017, 12:50 PM
  #277
flg8r22's Avatar
I could use the Weber, door panels, and floor mat
Old 04-22-2017, 01:55 PM
  #278
Lol I'm probably gonna build this truck. I'm about to check the gears, but I really think it's got 4:88s. No way stock gears could turn 33s this easily. I have another floor mat that's brown though.
Old 04-23-2017, 05:05 PM
  #279
All new parts on the 84:
brake master cylinder
brake booster
calipers / pads
steel braided brake lines front and rear
While bleeding the brakes a metal supply line beside the gas tank busted and let all of my fluid out. Disconnected the lines under the passenger fender and used a short line with two male ends bent into a U to block off the rear brakes.
I'm covered in brake fluid dirt and frustration. lol
Old 04-23-2017, 05:19 PM
  #280
flg8r22's Avatar
Thats where my 80 let loose. And several others. I keep the new lines i install as far away from there as possible
Quick Reply: 1984 Toyota Pickup 4x4
