rebuilt toyota 22R and W56 5 speed 4X4 trans, San Antonio TX
for sale i have a rebuilt toyota 22R and a W56 5 speed manual 4x4 transmission that came out of a 1982 toyota pickup from San Antonio TX
engine has brand new
brearings
rings
rocker arms
LCE mild torquer cam
LCE oversized valves
LCE valve keepers
cap and rotor
points pick-up module
NGK spark wires
newish fuel pump
i polished the ports and abit into the intake manifold. EGR deleted. i had the head cleaned and plained flat and the connecting rods checked by a machine shop. plasigauged the bearings for fitment. stock the engine made 97 hp and 129 tq and i guestimate probably 130ish hp and 160ish torque.... the block its blue with black and green accents the valve cover is blue with custom 22R emblem has stock intake manifold and almost brand new stock carb only had 300 miles on the carb. stock exhaust manifold, stock air filter housing (no air filter) engine runs great properly broke-in engine in accordance with LCE break-in procedure.
the transmission is in decent shape the transfer case needs new output seals. right now i have the transfer case separated from the transmission and both have been drained i was gonna open both to clean them but i scraped my project because i dont have a welder or the tools to do any fabrication work at the moment and also gonna use the money for a down payment on a car...
$1300 for both the engine and trans OBO ill consider any decent offer....
brearings
rings
rocker arms
LCE valve keepers
cap and rotor
NGK spark wires
newish fuel pump
