I've hit a snag
I've hit a snag
Ok so I've been doing research on the om617 swap and I'm pretty damn confident about it, but the only thing I'm worried about is the trans cooling lines that are integrated into the 22re rad. Will these cooling line match up to the mercedes rad? Or any ideas for the trans cooling?
If i run a small cooler where would be the best spot for it to get good air flow. I plan on putting a pusher fan in front of my rad, and i dont like trans coolers that are on the undercarriage[had some bad experiences with them and getting hit with debris]
i would run a aftermarket one.
iyou have an automatic ?
here is an idea for a mount anyware type of coller
http://www.monstermarketplace.com/di...mission-cooler
yeah its a auto, damn that cooler is alittle pricy, I'm trying to do this swap and motor rebuild for under 1000
Just thinking out of the box a little but how about an off center or center small hood scoop and mount it to a bracker/holder on the under side of the hood with enough hose to flex when the hood is open. just an idea its always a battle of money vs what you want
I am going to put the OM617 oil cooler in my hood.
As for price im sure you can fine a cheaper one that’s the first one I found with a good picture.
And trans or oil cooler will work with any fan as long as you make a good fitting shroud
http://www.ebay.com/itm/Mishimoto-Transmission-Trans-Cooler-Kit-MMOC-F-Heavy-Duty-Universal-w-Fan-Kit-/271088101461?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f1e1c2855&vxp=mtr
Just run a V6 auto rad, has roughly same coolant capacity as the merc rad, mounts flusher to the core support than a 4cyl rad and tranny cooler lines should hook right up. Still wouldn't hurt to add an auxiliary cooler down the road, heat is the #1 way to kill an automatic.
live4soccer7
05-11-2016 06:52 PM
kbpickens
10-02-2015 03:37 PM
