so i got a 2.7l tacoma engine and trannie dirt cheap.....
gona try to get it into my 92 i got it for 140$ got 119k on it the guy had it in a truck that rotted out and was moving wanted it gone so i offerd 100 bucks he said no so i said 140 and he took it. i got a wire harness from ecu or what ever u want to call it to the engine and a trannie from a 2wd, my buddie has a ton of parts for these engines o if i break something i can fix it for free, now the hard part is wireing. has anyone dones the swap i see a few from along time ago seem like just wreing was just the issue? and comments or concerd feel free!! drive yota!
so i got the 2.4 2rz not the 2.7 so im using the 2rzs 5speed bell housing with my r150f? (does that sound right for the 3.0v6) and gona make motor mounts. i have the wire harness from ecu to everything but no ecu. what ecu do i need? will a 3rz 2.7 4x4 work?
the bell hoising off the 3rz and 2rz will bolt up to a w56 or g54 4 cyl transmission, as for the ecu, u need one off a 2rz from the same yr of the motor and harness.
these are great swaps for 4 cyl trucks, but ive never done one with a v6. marlin makes a bellhousing to put the 3rz/2rz in front of the r series transmissions
ok thanks and i though it had to be the trannie from the v6? it dont matter i have tons of tannys and bell housing all diffrent kinds guss ill see what one fits? how do i tell what is what like the w56 or w55? i dont no how to tell by numbers i only now what year and what what they came outa haha but i hope it will be good with my 33x12.50 and its guna take some time to swap
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
07-08-2015 07:15 PM
Jnkml
07-06-2015 01:20 PM
