91 3.4 swap no spark
Old 01-31-2017, 06:13 AM
TacoGuy's Avatar
Hey guys not to beat the dead horse or anything but in the middle of a 3.4 swap with a buddy neither of us are wiring geniuses by any memes but not idiots either. My issue is im not getting any spark but getting power all the way to the coil packs. The igniter is plugged in the ecu has power the starter and efi relays and fuses and wired and that's as far as I've gotten. I figured that should be enough to see if I could get spark but still no spark. I'm just wondering if anyone could think of something I could be missing before I go through and tear apart all my wiring and re starting. Thank you in advance for any inputs.
Old 03-26-2017, 11:52 AM
mruuuk357's Avatar
I am having the same problem. Have you figured out what is wrong?
Old 03-29-2017, 10:47 AM
mbomberz1's Avatar
Do you guys have your igniter grounded? The little rectangle box on the very bottom of the picture here:
Just a though. From what I read and did, you need it bolted/grounded to the fender.
Old 03-31-2017, 10:40 PM
totally a bro
Staff
vital22re's Avatar
What year is your donor? did it have an imobilizer? if so, unless you grab the key, amplifier, and transponder ecu..... that ecu will not fire.
Old 04-17-2017, 06:38 PM
-burzum-'s Avatar
check for proper voltages and continuity at igniter / ecu to make sure you have good connections and no broken wires.
