CODE P0441 on 1997 4RUNNER SR5 3.4 LITER
Old 05-09-2005, 01:56 PM
BOSTON4RUNNER's Avatar
I just got this code, I got two fault codes with the same designation of P0441
it is on a 1997 4 Runner 3.4 5 speed...something to do with purge valve emissions stuff?
could it be a faulty gas cap? please advise any and all help is greatly appreciated.
thanks, Tim
BOSTON4RUNNER is offline
Old 05-09-2005, 02:00 PM
Ironmike4x4's Avatar
Yeah check the gas cap to make sure it clicks when you tighten it, if it still shows up with a code then take it to a technician to do a "smoke test" and find out where the leak is or if a valve is malfunctioning.
Ironmike4x4 is offline
Old 05-09-2005, 02:05 PM
i have reviewed the other threads on here about this
i am pretty certain no vacuum leaks exist
idle is good, i am going outside now to snoop around this evap valve,,,maybe take it out, clean it even
any other thoughts
Old 05-09-2005, 06:12 PM
i bought a new gas cap and also blasted some WD40 through the valve, perhaps that will help with it sticking
if not will buy a new one and swap it in
Old 05-10-2005, 01:08 PM
Did it work? I don't have any other ideas other than a leak somewhere around the gas tank or hoses.
Old 05-11-2005, 10:39 AM
it is out for now...but when it comes back on i will get that VCV valve....as of what i understand that is what the P0441 code designates.....perhaps it is stuck
it looks like a very easy swap and costs only 40 bucks
Old 05-12-2005, 08:59 AM
BADLNDS's Avatar
boston and ironmike,
decided to update you guys on boston's post. There is actually a "TSB" (technical service bulletin) for this EVAP problem. It's a design flaw in toyotas and i saw it last night under my truck with a mechanic/engineer.
The problem is when you fill up...and you try to squeeze that extra fuel in to even up the tab (top off)...because of the placement of the system (charcoal canister and the VSV) which is located near the fuel tank and close to the spare under the rear axle...because of where it sits and that it is not placed higher than the fuel tank...if you top it off fuel tends to saturate the canister and gives codes P0440, P0441 & P0446. It's really a stupid design flaw that happens to alot of toyota owners (not limited to 4Runners)...and Toyota won't help you cause the TSB states that the repair is a not applicable to warranty!
My buddy said to drive it for a while and keep the fuel low (give it a chance to dry up)...but...if the light keeps coming on...then i won't have the choice but to do the repair (and it ain't cheap...the parts are $$$) I have the repair guide in case you want to tackle it yourselves (I can e-mail it to you...PDF file)
from now on i will stop topping off...hope this helps. I found alot of stuff on this problem lastr night and alot of unhappy campers. (cause it's a defect that costs alot to fix)
Good luck with the light not coming on!
-B
BADLNDS is offline
Old 05-12-2005, 10:21 AM
mt_goat's Avatar
Sounds like this needs a sticky. Is it just with the 3.4L?
mt_goat is offline
Old 05-12-2005, 11:37 AM
BADLNDS's Avatar
don't think it's for the 3.4L only...dates back to previous models?
TSB (technical service bulletin) EG003-98
Title : EVAP System Diagnosis P0441/P0446
Date : April 3, 1998
Affected vehicles: All RAV4, Tercel, Paseo, Camry, Avalon, Tacoma, 4Runner, T-100 that display codes P0441 or P0446
BADLNDS is offline
Old 05-17-2005, 04:48 AM
thanks
so what about the valve in the engine compartment that others pointed out and replaced
i never top my tank off
the valve costs like 40 bucks so i am thinking i should replace that first
Old 05-18-2005, 07:03 AM
light went off again, codes say 1 of 2 codes P0441 then says 2 of 2 codes P0441
so I got two fault codes,,for the same thing? that vacuum switching valve....
so I am going to replace the valve, I took it out last night, blasted some cleaner through it, maybe it is stuck? all gummed up
figure I would do that for now since I didnt have the new valve last night
Old 05-18-2005, 07:14 AM
BADLNDS's Avatar
Lemme know what happens...update if its fixed it or light comes on again.
-B
BADLNDS is offline
Old 06-14-2005, 07:10 AM
replaced it
was off for a week now came on again
read about it here
https://www.yotatech.com/forums/f16/vacuum-switching-valve-vsv-constantly-switch-tick-when-running-p0441-please-help-61152/
06-01-2021 01:51 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Cplmike
07-08-2015 08:47 PM
Jnkml
07-06-2015 01:20 PM
coryc85
07-06-2015 04:07 AM
Quick Reply: CODE P0441 on 1997 4RUNNER SR5 3.4 LITER
