3.0 temp sending gauge unit
Old 04-06-2005, 07:47 PM
bryan's Avatar
3.0 temp sending gauge unit, where is it? Their are three sensors in the back drivers side. Which one runs the gague? Thanks
bryan is offline
Old 04-06-2005, 08:59 PM
Bumpin' Yota's Avatar
uuug this shouldnt have been moved!
Agreed and which one is the ECT sensor? The TFSM sucks ass in this one regard...
Bumpin' Yota is offline
Old 04-06-2005, 09:01 PM
dwh91102's Avatar
bryon its the one closest to the drivers side, just has one metal prong on top
dwh91102 is offline
Old 04-06-2005, 09:05 PM
Marc P's Avatar
It is a 2 wire guage in the center of the engine between the plenum and the firewall. It unplugs and I think its a 22mm deep socket you need to remove it.
Marc P is offline
Old 04-08-2005, 08:14 AM
bryan's Avatar
Thanks for all of your help I found it, and it checked bad. Hopefully this will fix my gague. thanks agian
bryan is offline
Old 04-08-2005, 03:57 PM
trd6209's Avatar
Not to confuse things but I just went through this last week. The Coolant Temp Sensor is the small one with the gray 2 prong connector directly behind and below the throttle body. It took a 19 MM socket to remove it I believe. The BIG one that looks the same only bigger directly in the middle area of the Intake took a 22 MM socket to remove, but the part did cross with what I was given at the parts store. I cross-referenced the part number on the side of the sensor and it turned out to be the Cold Start Injector sensor (Black Connector). I just want to make sure that we are both on the same thing. After I changed the "little gray one" my temp needle stopped bouncing all over the place, but my problem was intermittent anyway so I cannot be 100% sure until I drive it for a good while. If I am wrong, please let me know, if not then I hope that I helped out a little.
trd6209 is offline
Jdgarrison
10-01-2015 05:22 PM
gary4runner
09-24-2015 12:53 AM
Nickyodaman
07-27-2015 12:13 AM
Tyler Cunningham
07-11-2015 10:18 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: 3.0 temp sending gauge unit
