SAS FJ60 with axle housing flip and front shackle for my 2001 Tacoma
Old 05-19-2017, 06:54 PM
  #321
ZUK
ZUK's Avatar
Originally Posted by dropzone
I think that would be pretty cool set up. My neighbor had a similar axle set up by Proffit's Cruisers a few years ago. That 9.5 was pretty awesome sitting there.
Looking to see how you do the axle tube merger
I have to remove and strip the 8" housing down....then make a jig. Capture the 4 holes on each end of the housing with very rigid mounts.
Making sure the gasket mounting surface is perfectly level with a bubble. And the rest will fall right into place. I have a 9.5" 3rd member that needs a little building up first.
Stay tuned.
Old 05-20-2017, 04:08 PM
  #322
ZUK
ZUK's Avatar
Realizing that a proper "triangulation/fisheye/spreading of the stresses is needed, I had to spend 40 Big Ones for a one foot piece of DOM.
ID equals 3.124" is perfect for some reinforcing plates.
If the above picture(s) do not show up properly then Clear the cached images by hitting Ctrl/Shift/Delete all at the same time....then do a refresh.
Old 05-25-2017, 01:09 PM
  #323
ZUK
ZUK's Avatar
This just arrived....
BIG Nitro stickers! biggest I've seen.
Waiting for the ebay 9.5" 3rd....and the DOM tube still.....
Old 05-25-2017, 02:00 PM
  #324
Fossilized
Staff
dropzone's Avatar
that is a thing of beauty
Old 05-25-2017, 02:56 PM
  #325
ericwudi0830's Avatar
looks pretty sweet
Old 05-26-2017, 12:51 PM
  #326
ZUK
ZUK's Avatar
Originally Posted by ericwudi0830
looks pretty sweet
Stay tuned Eric and Robb.....the 12" chunk of DOM just arrived.....still waiting for the bare 3rd to arrive.
Just arrived.....
They said it would be 12 inches....I measured 11 31/32....I guess that will suffice.
Wall thickness is a perfect .188 to match the thickness of the axle tubes which I think is right around the same number.
Chopsaw time.....
Old 05-26-2017, 03:37 PM
  #327
rustED's Avatar
Cool project, I'd be scared to death to start cutting, lol...can't wait to see some more pics!
Old 05-26-2017, 03:40 PM
  #328
ZUK
ZUK's Avatar
Hell....I'm scared to death already So I'm getting all the prep work out of the way before the actual heart transplant happens.
Lotta hand grinding with a cutting wheel.....
2 done and 2 to go. Only 99 outside in the shade.
Old 05-26-2017, 05:05 PM
  #329
ZUK
ZUK's Avatar
The 4 axle housing half plates are ready....2 on each side. Beefs up the housing at those 2 vertical stress points
such that I never have to worry about THAT spot on the housing ever again....it's all the other spots......
Old 05-30-2017, 06:24 PM
  #330
ZUK
ZUK's Avatar
The final piece of the puzzle arrived....in the exact rusted condition I expected. This is going for a sand blasting.
Old 06-01-2017, 12:24 PM
  #331
ZUK
ZUK's Avatar
Got the rusty 3rd back from B & B automotive in Mesa.......
Clean enough to rest on my mouse pad......
Old 06-06-2017, 08:23 PM
  #332
ChinkTruck's Avatar
Thank goodness none of that pitting got in the journal or thrust threads. Lucked out there, Any updates? Were all getting a little impatient! Lol
Old 06-06-2017, 10:03 PM
  #333
ZUK
ZUK's Avatar
Got to get rid of this pneumonia first.
Old 06-06-2017, 10:07 PM
  #334
ChinkTruck's Avatar
well now I just feel like a dick! Get well Zuk, let us know when you beat it.
Old 06-06-2017, 10:14 PM
  #335
ZUK
ZUK's Avatar
No Biggie
Old 06-11-2017, 10:27 AM
  #336
ZUK
ZUK's Avatar
Still kinda sick but feel good enough to do an hour on the FJ60 rear ....and then a gearinstall for a customer.
Just doing some fitment possibilities.....the empty 3rd dropped right in in normal mounting position. Brackets are in the way of future plans so they will come off.
2 of the the studs have to be extra long because of the thicker mount holes.
Here, I turned the 3rd upside down and fits perfect.
This is the backside. The 3rd fits in both orientations here also.
Now I was going to sawzall this bracket off.....
...but it was actually going to be cleaner by breaking the welds with my cutting wheel and flapper it down.
Sawzall took care of this one.
Flapper wheel cleaned it up nice. And there is still a lot of high weld spots and sputters that need to be levelled off a little better.
The plan is to remove those studs and have a perfectly flat surface to allow a long bubble leveller to lay across the gasket surface.
The welds may need additional levelling.
Sawzall it.....
Old 06-11-2017, 12:41 PM
  #337
rustED's Avatar
Looking good. You get more work done when you are sick then I do when I'm 100% healthy, ha, ha. Glad you're feeling better!
Old 06-11-2017, 01:23 PM
  #338
ZUK
ZUK's Avatar
Ha!
This perch was in the way.
These axle housing studs get swapped on opposite sides.....double-nut and a touch of heat. They felt like they would come out without the heat but the application
of the heat made them spin a lot easier.
All 20 studs were high speed wire wheeled. Axle housing is ready to be taped off and cut.
The plan is to NOT have a drain plug on the bottom. Plan to flip it to the top.
Old 06-18-2017, 05:31 PM
  #339
ZUK
ZUK's Avatar
Got the clean 3rd....
got all the parts.....forgot to put the new Koyo pinion bearings in the pic.....
Old 06-18-2017, 05:43 PM
  #340
ChinkTruck's Avatar
You staying with the open diff? Or do you got a locker stashed away in that shop?
Quick Reply: SAS FJ60 with axle housing flip and front shackle for my 2001 Tacoma
