HID Projector Retro 7x6 sealed beam
Getting around to doing the retro on my 92 pickup. I have had these projectors laying around from my previous retro just waiting to go in the yota.
The projectors are Acura TL bixenon projectors with clear lenses.
The other equipment is Hella ballasts, and a Morimoto H4 relay harness (3yrs old used everyday and not a single issue). Pilot housings which are preferred because of them being completely plastic.
And i got started on one housing already
The core is fine. The headlight bucket on the other hand will need to be cut to allow the projector to protrude through. I do not know how much yet but i dont think it will be that much.
The only thing that i think will need to be addressed is the battery but i wont know that until i set them in place.
Getting started installing the harness and test fitting the housings, i ran into a few obstacles.
One housing fit into position
As you see here my battery will now not fit. No way, no how!!
The battery is old and i have another vehicle that needs one so i can sell it, so its going in that vehicle. Now the new battery im going to purchase is made specifically for Toyota....
Having a few difficulties. Got one light mounted tonight but need to figure out a way to seal the reflector bowl where the cut off shield sticks out the back of the solenoid. New battery came in but I did not know it had the JIS terminals so I can't install it and with the original battery in place I can't install the other projector and housing.
Gotcha
the solenoid area is under the projector, with the spring exposed?
Could you use a rigid plastic or ABS then epoxy that to the housing? Maybe a job box from DigiKey or Mouser cut to accommodate the housing.
Yea that area. Its open straight to the internals of the projector. I have some old legos my boys dont play with anymore that im going to check out. It wont be much work to seal it since its 4 sided with a top.
