head unit not functioning
i was working on installing a sony head unit in a 1987 4runner and i got it hooked up and working with the front speakers. i took it out and started putting on splices for the rear speakers. when i reattached the cd player it would no longer power up the display or anything, but it will take a cd and eject it as well. any ideas or help is appreciated
bump for help all the wires are connected correctly and i have no clue what is going on all the fuses under the hood are fine and the fuse on the back of the head unit is fine too
Sounds like constant power is still there. Check the ignition wire going to the head unit. The unit will still take CDs and eject them with the constant power attached.
If you want, take a spare wire and run it from the positive on the battery and hook it directly to the yellow wire coming from the Sony. Or simply run a little jumper wire from the red wire to the yellow one and see if it turns on.
red: constant power
yellow: ignition
red: constant power
yellow: ignition
kinda off topic but can eney body point me in the right direction to a good ipod capable head unit and good speakers bigger than stock that will fit in the stock location in my 94 ex cab pickup. i belive i will need 4. ive never started a system from scratch but all the trucks speakers are blown and shes got the stock AM/FM radio. thanks for the help
Blamalam
03-12-2022 07:34 AM
Odin
07-15-2015 09:28 PM
icentropy
07-14-2015 10:23 AM
