93 4runner window up with tailgate down
So on my 93 runner I had to swap ignition switch out. Now I want to re key all the door locks. The only one I'm having a problem with is the one on the tailgate because of the rear window. The question is how do I let the window up while the tailgate is down. So I can remove lock without completely removing the window. Thanks in advance
easy peasy
what you need to do to roll the window up with the gate open is to close the latches on both sides of the gate, put a screwdriver in the slot in the latch where it catches when closed and roll the catch to the closed position. then you can roll the window up while supporting the glass. be careful not to roll it out too far without support
when you reverse the process you will need to pull the handle and at the same time use your screwdriver to pull each latch to the open position. they don't spring open when you pull the handle and if they are closed when you try to slam the tailgate shut.... no bueno!
trbbhm
07-09-2016 11:15 AM
