1993 Yota headlight upgrade ????
I just bought a 1993 Toyota pickup extended cab. The stock headlights are pretty dim so i'm looking to upgrade. I've seen the Hella kit you can get along with a couple other options. I was curious what people would recommend for a brighter upgrade. I've also seen an LED option but i'm not sure how those are for people. Any feedback is appreciated. Thanks in advance!
In the middle of upgrading my 94. I went with the autopal e-code (euro version). They're MUCH cheaper and from what I understand, very comparable to the hella e-codes. The cool thing about switching to either option is ditching sealed beam headlights and moving to an H4 style. So once either option is installed, you have two more options for even more light. Better bulbs. I think the autopals come stock with 60/55W bulbs, you can get much brighter ones. The problem is, the stock wiring isn't really meant to handle those sort of headlights. So you will want to switch over to a relay system. Not only will the truck be able to handle these more powerful headlights, they will also give them more power. You don't have to get brighter bulbs. I won't be.
My plan is autopals for a bit. Then relay. And if I'm still not happy, better bulbs.
I got these: http://www.ebay.com/itm/86-95-TOYOTA...-/330397530576
I will be most likely doing the relay stuff myself. These links can help you out:
http://www.4crawler.com/4x4/CheapTri...adlights.shtml
http://www.rowand.net/Shop/Tech/Wiri...ightRelays.htm
There are relay kits on eBay and other sellers, but do a little research before pulling the trigger on one. Thanks Co_94_PU
Hope that helps! I've also read that swapping out the headlamps can be a pain because of the grille and people suggested buying grille clips before working on it because they break easy. Guess I'll find out soon enough
Either that harness is flawed or the photos are, it is grounded on the wrong terminal at the lights and would need checked out and re-pinned . I'm considering one of the ebay cheap harnesses just to get all the plugs at once. Very few of them give the wire gauge or a diagram, both of which are kind of important when choosing!
