General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
1993 speed sensor not working
Old 11-27-2016, 01:52 PM
Dennisx2's Avatar
Hi everybody! I tried this on another forum but did not get any answers even though there were 163 views so I thought I would try it here hoping for an answer.
From what I can glean from the electrical FSM for my 1993 4cylinder plain vanilla p/u w/ac, 22re engine and no cruise control. The #2 speed sensor located in the instrument cluster is what appears to be used only with the electronic controlled transmission and overdrive function or . Does anyone know if this is correct or am I interpreting the manual incorrectly? The #1 is located speed sensor in the tail shaft housing and appears to be used only for the speedo and odometer for the manual transmission. Can anyone confirm my reading of the manual.
Thanks to all
Dennis
Old 12-02-2016, 01:24 PM
wyoming9's Avatar
Red face
I can see why no responses
Just what do you have ??
Auto or Manual ??
Just what is happening if anything with your speedometer ??
Old 12-03-2016, 09:27 AM
Dennisx2's Avatar
Wyoming9...Thank you for your response!! My truck has a 5 speed manual transmission. The other things that happen are that the speedometer works sometimes. There is no reason that I can discern when it will work or not work. Sometimes the odometer will work and sometimes it will not. When it does work it does not make any difference whether the speedometer is working or not. If you have any further questions please feel free to post them on the forum and I will reply as soon as I read them. Thank you again!.
Old 03-19-2017, 09:45 AM
Dennisx2's Avatar
Wyoming9...I was just wondering if you have read my reply to your questions? Would appreciate an answer if you have time.
Thank you in advance!
Dennis
Old 03-20-2017, 02:26 PM
wyoming9's Avatar
Red face
Since it seems to be a intermittent issue I would guess a loose corroded connection at one or more of the plugs
A poor ground for that circuit.
Wires in the harness rubbing causes a open circuit
One of those things you need to be up close and personal
Without the EWD for your vehicle I am not sure just what values you need to see from the speed sensor
Any other electrical devices not working
