Zuk Mod - YotaTech Forums
Off Road Enhancements Enhancements to improve your off road travels
Zuk Mod
LinkBack Thread Tools Search this Thread
Old 02-27-2012, 07:54 PM   #1
Surf Runner's Avatar
Zuk Mod
After being a fan of the site for quite some time and reading others successful stories, decided to do a zuk mod on my 86 4runner SR5. When i bought my truck it had 3" blocks in the back and the torsion bars cranked up to fit 35's under it. I previously added the ball joint spacers so i could smooth out the ride up front, but because of the off the blocks i was still breaking u-joints and had a low weight capacity for towing and payload.
flat leaf springs before the start of the job
with the tires off, remove the leaf spring u bolts and in my case the blocks and make sure you have supported the axle.
my bolts to the leaf spring hangers didn't really want to come out so i improvised to get some extra room in there.
i used stock jeep springs from a friends rubicon. there are two lengths and and diameters under those jeeps, luckily the shorter and wider ones pretty much fit perfectly around the bumpstops between the leaf and frame without any problem. used a torch to slightly bend the ends to better fit around the stops.
reassemble and repeat on the otherside.
no more blocks and even more clearance by about 1".
i recommend the zuk mod for any older toyota and especially the 4runners. after putting about 5k on it since this mod i can say my horrible body roll and constant fear of flipping while turning is gone. the zuk mod stiffened up my rear end so much i can load my truck with tools and have 4 guys stand on my bumper and it barely drops with all the weight. front axle swap with more detail and pics are coming soon
Surf Runner is offline   Reply With Quote
Flex with a rear end ZUK mod punks_is_4x4 Offroad Tech 12 05-31-2016 06:03 AM
Voids 1987 4runner 22re turbo - in over my head voiddweller 86-95 Trucks & 4Runners (Build-Up Section) 53 02-01-2016 05:46 AM
Newb looking to do an ENTIRE drivetrain conversion on 2gen 4Runner TheBFA Solid Axle Swaps, All Years 6 10-01-2015 12:18 AM
rear lift options oldblue 86-95 Trucks & 4Runners 0 09-28-2015 04:07 PM
Second Ge Tacoma SAS Project90 Solid Axle Swaps, All Years 0 09-24-2015 11:40 PM
Tags
35, 4runner, 86, fit, leaf, mod, mods, spring, springs, tech, toyota, yota, yotatech, zuk, zukmod
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
