why is it bad to replace ATF.??
Old 12-12-2005, 06:37 AM
nrgetic99's Avatar
Originally Posted by NESW20
i disagree with the part about not using a flush machine. get that old fluid out of there ASAP, using whatever method is available. many flush machines use the tranny's pump to actually pump the fluid, so it's not going to cause any problems by having too much/too little pressure while it's flushing.
-Mike
The pressure is not the issue Mike... the risk of blocking one of the oil galleries is.
This is a documented problem.
David
icentropy
09-16-2020 02:47 PM
snosurfer
3.4 Swaps
03-29-2016 11:29 AM
TURBOrunnerNM
07-22-2015 11:01 AM
smiley52
07-11-2015 05:16 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: why is it bad to replace ATF.??
