centering the front wheel
Old 04-23-2017, 12:13 PM
AAMoussa's Avatar
Hi,
I just upgraded my 2010 tundra suspension to King OEM Coilovers with Camburg A-arm. Now, the off road shop cannot not center the drivers side front wheel in the fender well; the tire rubs when I back up. They managed to center the left side. I spoke with their alignment special, he said it cannot be done because it will not be alignment, is this true?
I have 35" wheels on my truck. Prior to the upgrade, I had leveling kit and there were not rubbing. Cannot you provide some tips?
Old 04-23-2017, 02:21 PM
Co_94_PU's Avatar
If they can get one they should be able to get the other. Maybe a part defect, bend frame or need to tweak the installed parts
Old 04-23-2017, 03:00 PM
Fossilized
Staff
dropzone's Avatar
Originally Posted by AAMoussa
Hi,
So I am confused, or is this a right hand drive Tundra? They can't center the driver's side (usually the left side) but they managed to center the left side...
Have you owned the truck since new? any record of front end damage? Did you have it aligned prior to the lift so you have previous record to go from?
22R88
10
06-01-2017 06:46 AM
jdmhiluxsurfer
05-20-2017 10:06 AM
jiju1943
04-21-2017 09:27 PM
jkgts1
04-10-2017 10:17 AM
Neemox
04-09-2017 07:12 PM
Quick Reply: centering the front wheel
