What gas milage do you get with 5.29 gears?
Old 10-15-2009, 11:58 AM
eastsideyota's Avatar
i have a 6 inch fab tech with 35's and i wana get new gears but i am a student so gas money is tight. does any one have 5.29 gears with 35's?? if so could you let me know what kinda milage your gettin. thanks
Old 10-15-2009, 12:07 PM
camo31_10.50's Avatar
i've come to realize..even if you make up for the tires with gears...you still have this big lift..and these big tires..so even with 5.29's...your gas mileage is still gonna be
with that being said my runner has a 4in lift and 33's with 4.56's and im gonna take it up to 4.88's in hopes of better gas mileage..LOL
Old 10-15-2009, 12:12 PM
mastacox's Avatar
It's likely you will actually get BETTER mileage with 5.29's, since that will get you back to stock gear reduction when you take into account your bigger tires.
Old 10-15-2009, 12:20 PM
JamesD's Avatar
False. With a lift kid you add more weight and with bigger tires you add even more. You can regear it but weight is weight. For an example, lets say the tires and lift kit weighs a total of 500 lbs. Take your stock 98 4Runner and put 500lbs into the truck, do you think your gas mileage would increase? Regearing does help but you still have to move the weight.
James
Old 10-15-2009, 12:40 PM
exactly..
the reason i am doing it is for the gas mileage..because right now..it will take alot of pedal to get the runner up to 70mph..well..with 4.88's it will take less pedal to get it to 70mph..same with the 5.29's and 35's..
99.9999% sure it wont HURT your gas mileage..unless you just fall in love with the new found 'power' LOL
Old 10-15-2009, 03:09 PM
mastacox's Avatar
James
He already has 35's and a 6" lift, with stock gears. I'm saying that he will probably get better mileage with 5.29's than he currently is with his stock gearing.
Old 10-15-2009, 03:48 PM
JamesD's Avatar
Ahh! My bad.
James
Old 10-15-2009, 06:35 PM
dannomite's Avatar
Also the larger tires decrease engine RPM at a given road speed. When you put the engine closer to its peak torque you will also increase its efficiency.
smthwsn357
12-04-2023 02:08 AM
pyramid
07-30-2015 10:05 AM
coffey50
07-28-2015 10:55 AM
daddio
07-18-2015 10:20 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: What gas milage do you get with 5.29 gears?
