truck weight
my 85 stock 4runner is at 3150 with the shell on and the shell weighs in at maybe 200lbs and the roll bar I dont no maybe 100 lbs , so without the shell and roll bar about 2850 lbs give or take, so maybe fig out the weight diff of the v8 and trans and if you added heavy bumpers and big tires etc, I have 225-75-15 tires on mine so there under 30 lbs each,, oh I just forgot toyota changed body style and things in 89 truck so I dont no if the 89s weigh more or not
depends on model, but the truck ways any were from 2565 to 3565. add 580 for the small block, 130 for the th350 and 125 for the np205 and you get around 4400 pounds max. subtract the weight of a toyota drivetrain and you will be around 3800 pounds give or take a couple hundred pounds depending on what you have now.
