removing steering wheel
Old 10-04-2009, 04:36 AM
bain's Avatar
how do you remove a 98 tacoma steering wheel with airbags? I need to straighten it up..
thanks
Old 10-04-2009, 05:37 AM
olharleyman's Avatar
FIRST DISCONNECT THE BATTERY WAIT ABOUT 10 MINS TO DRAIN ANY POWER then you need to remove the screws holding the horn pad in place lift the horn pad and but watch out you don't pull it up to fast because the air bag wires need to be disconnected before you can remove the pad all the way.
Old 10-04-2009, 05:45 AM
FredTJ's Avatar
Originally Posted by bain
<SNIP> I need to straighten it up..
thanks
?????? How in the world did it get messed up to start with ?
Fred
Old 10-04-2009, 07:32 AM
bain's Avatar
Fred
hard to explain
Old 10-04-2009, 07:48 AM
FredTJ's Avatar
hard to explain
Well if you wacked something with the front of the vehicle, then you simply need to fix/replace/adjust whatever you pooched up. Also get it aligned.
Fred
Old 10-04-2009, 08:11 AM
bain's Avatar
Fred
Yea Im trying that today
Old 10-04-2009, 08:26 AM
FredTJ's Avatar
It shouldn't be a "trying" thingy, it should be a "doing" thingy
Re-clocking the steering wheel isn't going to solve/fix the pooched front end problem.
Fred
glowz825
01-25-2022 09:28 AM
coffey50
07-28-2015 10:55 AM
terminator
07-27-2015 07:13 PM
voiddweller
07-15-2015 03:56 PM
Quick Reply: removing steering wheel
